Automation Guide: AVID NEXIS Client Manager on macOS intel / silicon
  • May 19, 2025
  • 4 replies
  • 779 views
Hello everyone,
After spending hours digging through forums trying to find a reliable way to fully automate the AVID NEXIS Client Manager installation on macOS, I’m sharing this step-by-step guide to save others the same trouble I went through.
Unfortunately, Avid doesn't provide much help on this topic, so I hope this helps streamline your deployment.
I’m aware that this isn’t the most secure or ideal approach, and there’s definitely room for improvement — but it works for us.
If you have suggestions or improvements, feel free to share!
If this can help new Mac admins or anyone else, all the better!
Useful resources I consulted:
System Security Prerequisites
Before any installation, it's critical to adjust macOS security settings to allow the required kernel extensions for AVID NEXIS to load properly.
For Apple Silicon Macs (M1/M2/M3):
Boot into recovery mode, open the Startup Security Utility, and:
  • Set security to "Reduced Security"
  • Check "Allow user management of kernel extensions from identified developers"
For Intel Macs:
Boot into recovery mode and run the following command in Terminal to disable SIP:
csrutil disable
These steps are required to enable the system to load the necessary kernel extensions.
PPPC Configuration
App Identifier to allow:
  • Bundle ID: com.avid.AvidNEXISClientManager
Code requirement:
anchor apple generic and identifier "com.avid.AvidNEXISClientManager" and
(certificate leaf[field.1.2.840.113635.100.6.1.9] /* exists */ or
 certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and
 certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and
 certificate leaf[subject.OU] = "4UYUA773XD")
Services That Can Be Preapproved (No User Interaction Needed)
You can preauthorize the following services via a configuration profile to avoid user prompts during AVID NEXIS usage.
Choose what’s relevant for your environment:
  • SystemPolicyNetworkVolumes
  • FileProviderPresence
  • SystemPolicyDocumentsFolder
  • MediaLibrary
  • SystemPolicyDesktopFolder
  • SystemPolicyRemovableVolumes
  • SystemPolicyDownloadsFolder
  • Accessibility
  • SystemPolicyAllFiles
KEXT: Kernel Extension Approval
Information required for your configuration profile:
  • Developer Name: Avid Technology Inc
  • Team ID: 4UYUA773XD
Kernel extensions to approve:
Display Name
Bundle Identifier
AvidNEXIS
com.avid.filesystems.AvidNEXIS
AvidUnityISIS
com.avid.filesystems.AvidUnityISIS
(Optional: Only approve specific bundles as needed.)
Deployment Steps
  1. Deploy the AVID NEXIS client installer PKG using Jamf or your preferred tool.
  2. Run a license/configuration copy script, if required.
  3. Reboot the machine with kext cache rebuild (no delay).
KEXT Local Path
  • Identifier: com.avid.filesystems.AvidUnityISIS
  • Path: /Library/Extensions/AvidUnityISIS.kext
  • May 20, 2025
Great job on this! I fight constantly with our communications department and configuring Nexis every year!!  uggh. But I just built this config profile and when it tries to install it says :
So not 100% sure where to go next....  I did unscope all other nexis Cps before scoping this one.
Thoughts or help welcomed...
-Todd
  • May 20, 2025
-Todd
Solved it, I copied the formatting, it didn't like the white space...   it deployed.
  • October 3, 2025
Hi there. I’m in the same situation. I have the PPPC and KEXT set up, but we’re still seeing the need to manually approve the system extensions in Privacy & Security. However, the KEXT i have does not have com.avid.filesystems.AvidFOS. The screenshot with that and the following text are confusing. Are the 2 in the table the optional ones? As I only have those two in the KEXT.
Would the addition of the FOS remove the manual approval?
Any info would be appreciated since I have had to manually approve 60+ computers… 😅 Thank you!
  • October 3, 2025
In addition, are the KEXT and PPPC profiles supposed to be combined or separate?
