Battery recall for 15" mid-2015 MBP
  • Jun 20, 2019 6:03 PM UTC
  • 31 replies
  • 364 views
Show first post
Mauricio11
  • Jun 26, 2019 6:54 AM UTC
One could use the 'Model Identifier' from the Advanced Criteria to create a smart group as a target for the script, reducing the scope and the workload on the system.
beeboo
  • Jul 1, 2019 8:51 PM UTC
@donmontalvo i tried this with a script and EA with smart group, however, while i can run the command fine, natively on the machine, it does run right as a script.
Error running script: return code was 126.
i assume its having difficulty making the directory for reason, maybe it needs a $currentuser or something to that effect defined vs just /library/ ?
  • Aug 14, 2019 1:13 PM UTC
Great script, thank you :)
Forum|alt.badge.img+31
  • Aug 15, 2019 5:02 AM UTC
@nicktong doing the Lord's work I see! Thanks, gonna steal a bunch of this at some point when I want to automate the battery checking
nicktong
  • Aug 29, 2019 5:44 AM UTC
@tlarkin lol, I can barely keep up with my own work, let alone... :) In any case, I have noticed that once a battery has been replaced, the response still comes back from qualityprograms.apple.com/snlookup/062019 as "Eligible" .. which is definitely annoying
  • Aug 29, 2019 8:44 PM UTC
I guess quality programs is just a clever name then :-D
