We've got some scripts that run before imaging and some for after to do
partitioning, writing fstab file etc etc. I've just noticed though that one
of these which is prioritised for running before is also attempting to run
after imaging. Anybody got any ideas why? Logs below, the offending item is
'pre-install-partition-v2.sh'...
Cheers
Dan
<LOG>
Storing SSH Account JSS...
Preparing installation...
Mounting afp://it01.insidecreative.co.uk/Casper-Packages...
Verifying Packages...
Verifying Scripts...
Running pre-install-partition-v2.sh...
Result of running pre-install-partition-v2.sh was: Total size of disk0:
111.8 GB
Raw size of disk0: 120 GB
CP-IntHD-01 Size: 60 GB
CP-Homes-01 Size: 20 GB
CP-Scratch-NOT-BackedUp Size: 10 GB
Restore Size: 20 GB
Partitioning encountered error Could not unmount disk (-10000) on disk disk0
Started partitioning on disk disk0
Creating Partition Map
Could not unmount disk for zeroing
Performing Block Copy of OS-10.4.9-Base-v1.0.dmg...
Enabling Permissions on CP-IntHD-01...
Installing ARD-Custom-Client-v3.mpkg-PPC.mpkg...
Installing Casper-QuickAdd-JSS-v2.pkg...
Installing iPhoto-v6.0.5-Univ.dmg...
Installing iWeb-v1.1.1-Univ.dmg...
Installing AirPortExtremeUpdate2007002.pkg...
Installing AirPortExtremeUpdate2007003.pkg...
Installing iTunes-v7.2-Update.pkg...
Installing JavaForMacOSX10.4Release5.pkg...
Installing QuickTime716.pkg...
Installing SecUpd2007-005Univ.pkg...
Installing SecUpdQuickTime716.pkg...
Installing X11Update2006.pkg...
Installing EXP250-Drivers-Full-v1.1.dmg...
Installing Mozilla-Firefox-v2.0.0.4-Univ.dmg...
Installing Adobe-Flash-Player-Safari-v9-Univ.dmg...
Installing Adobe-Reader-v8.1-Intel.dmg...
Installing EFI-CUPS-Fix_Installer.dmg...
Installing CyberDuckFTP-v2.7.3-Univ.dmg...
Installing Flip4Mac-v2.1.2.72-Univ.dmg...
Installing MS-WordX-v10.19-PPC.dmg...
Installing NeoOffice-2.1-Intel.pkg...
The package NeoOffice-2.1-PowerPC.pkg can only be installed on PowerPC
processors.
Installing Stuffit-Expndr-v11.0.2-Univ.dmg...
Installing VLC-v0.8.6-Univ.dmg...
Setting computer name to "CP-AVP-02x"...
Updating ByHost files to match 00:17:F2:DE:E5:72
Running disable-MS-PID-check...
Result of running disable-MS-PID-check was:
The script does not exist in the Scripts folder.
Creating /private/etc/jamf.conf...
Creating /usr/sbin/jamf...
Creating Startup Script...
Creating Login/Logout Hooks...
Creating /usr/sbin/jamfvnc...
Creating First Run Script...
Blessing System...
Ensuring system files are Hidden...
Unmounting File Server...
</LOG>
-- Daniel Farnworth
IT Manager
The Creative Partnership
daniel.farnworth at thecreativepartnership.co.uk
http://www.thecreativepartnership.co.uk
Tel: +44 (0)20 7439 7762
Fax: +44 (0)20 7437 1467
PGP Public Key available<BR>
Be the first to reply!
