best practice on how to upgrade our environment with an older Mac mini
  • November 4, 2019
  • 36 views
I've seen that a lot of the documentation on this site explains to cache the downloader from the App Store. however when trying this method I'm given an error saying that this version cannot be downloaded on this Mac Mini(Mid 2011). In our environment we have a lot newer Macs (2017 and newer). are there any work arounds for this besides requesting a new Mac(lol)
any help is much appreciated!
Best answer by mm2270
I'm trying to upgrade our other Macs in our environment(Mac minis, MacBook pros, Mac Pros, iMacs) to Catalina, which I know are compatible with the aforementioned Mac mini
It took me a bit of re-reading your post to understand what you meant by this, but I think I get it now. You're using the 2011 Mac mini as an "IT" machine of sorts to download the installer for Catalina, to upgrade the other Macs. Is that correct? If so, then I would recommend looking at this utility (http://dosdude1.com/catalina/), which will let you download Catalina on unsupported machines. Make sure to only use the download option and not download and patch.
Once you have it, you should be able to package it up or upload it etc. as needed to your Jamf environment.
  • November 4, 2019
What version of the OS are you trying to download to this particular Mac mini? High Sierra is the latest version 2011 mini's can take.
  • November 4, 2019
So I'm not trying to upgrade the Mac mini. it can stay at on High Sierra. I'm trying to upgrade our other Macs in our environment(Mac minis, MacBook pros, Mac Pros, iMacs) to Catalina, which I know are compatible with the aforementioned Mac mini(not sure if possible since I can't even download it from the App Store). sorry for the wonky explanation.
  • November 4, 2019
