Best way to create a custom pkg with custom options deselected
  • Feb 16, 2024 6:50 PM UTC
  • 6 replies
  • 149 views
janzaldua
Hi. What is the preferred/best way to create a custom PKG from the developer's PKG? An example is Cisco AnyConnect.
If I run the installer for Cisco AnyConnect manually, I get the options to deselect certain things, such as Web Security or ISE Posture. If I were to deselect these options, how could I make sure those options get deselected for everyone else when deploying via Jamf? (since it will install without a GUI) Would this be done via Automator?
YanW
  • Feb 16, 2024 7:01 PM UTC
mvu
  • Feb 16, 2024 7:18 PM UTC
There are other options, but you could use this:
1. Push the Cisco Secure Client Package
2. Add a post-install script (below) to run after
/opt/cisco/secureclient/bin/amp_uninstall.sh
/opt/cisco/secureclient/bin/dart_uninstall.sh
/opt/cisco/secureclient/bin/iseposture_uninstall.sh
/opt/cisco/secureclient/NVM/bin/nvm_uninstall.sh
/opt/cisco/secureclient/bin/umbrella_uninstall.sh
AJPinto
  • Feb 16, 2024 8:52 PM UTC
We stopped using AnyConnect a few years ago. However, unless something has changed, AnyConnect uses something called a custom.xml to customize the options that are installed when you deploy the client. This process is a complete and total mess, and we wound up doing what @mvu suggest with just installing everything and removing what we did not need.
SMR1
  • Feb 20, 2024 2:11 PM UTC
flyingdutchsys
janzaldua
  • Mar 19, 2024 11:53 PM UTC
Thanks everyone for the suggestions. Haven't gotten around to trying this yet!
