Hi
I am currently on Jamf Pro 10.30.1 .
I have configured patch management reporting for macOS Big Sur. But it is not listing the latest update 11.6 in the definition
 11.5.2 (20G95) is the latest definition. Any anyone facing similar issues?
11.6 is showing up in my patch management however the macs are not able to see the 11.6 update from the apple software update and I can't pull the 11.6 dmg using the softwareupdate CLI.
Did Apple pull 11.6?
Looking into this has found that Apple does not appear to be releasing 11.6 as a full installer. That is how we patch our systems in JAMF, by pulling the full installer and then using composer to create the .dmg file and then deploy that out. Not sure how to work on this now.
https://mrmacintosh.com/macos-big-sur-11-6-update-20g165-is-live-whats-new/
Anyone who finds a way around this, I would be interested.
