Big Sur and Cisco Anyconnect
  • November 19, 2020
  • 55 replies
  • 376 views
Show first post
daniel_ross
Forum|alt.badge.img+20
  • September 24, 2021
Our company is changing from Cisco to Forti, not only because of these errors...
Ditto here as well.   I'm sad the org (merger of 5 companies from last year) that I'm part of is going away from Global Protect.
  • October 26, 2021
Anyone having issue with AnyConnect denying the system from pulling softwareupdate list?
Below are the error message I saw in the console
System Policy: com.cisco.anycon(306) deny(1) system-privilege 10006
Violation:       deny(1) system-privilege 10006
Process:         com.cisco.anycon [306]
Path:            /Library/SystemExtensions/4EBB3FEE-890F-4AA7-9628-1DDAF928C676/com.cisco.anyconnect.macos.acsockext.systemextension/Contents/MacOS/com.cisco.anyconnect.macos.acsockext
Load Address:    0x10eddd000
Identifier:      com.cisco.anyconnect.macos.acsockext
Version:         4.10.03104 (4.10.03104)
Code Type:       x86_64 (Native)
  • March 7, 2022
Don't know if people are still struggling to create a custom Anyconnect PKG but I found this from someone awhile ago and saved it to a text file and keep it a folder on our share .  Don't remember the source.  Obviously you can use any temp directory I just do it from my Downloads folder.
Use directory: cd /Library/Application\\ Support/tmp
  1. Download anyconnect-macos-4.10.03104-predeploy-k9.dmg from Cisco (or your vendor) and open it via installer (Double Click it in finder).
  2. Drag the AnyConnect.pkg file inside the .dmg to your tmp (for simplicity) and then do @MikeF's steps (4-9 below):
  3. Open Terminal and cd /Library/Application\\ Support/tmp
  4. Pkgutil --expand AnyConnect.pkg AnyConnectVPN
  5. Went to the tmp folder, opened the AnyConnectVPN folder
  6. opened the AnyConnectVPN/Distribution file
  7. Look for <choices-outline> <line choice="choice_vpn"/> lines starting around line. Delete the ones you don't need, and Save. (I Used Xcode to edit the file)
  8. pkgutil --flatten AnyConnectVPN AnyConnect_4.10.03104.pkg
  9. Upload that pkg file to JSS and go from there in however you want to deploy it.
  • March 8, 2022
We don't need to pack a custom package. We can download our Anyconnect package by entering the URL of our VPN in a web browser. After login the site, Anyconnect is provided for the operating system of the connected client (Mac or Windows). The package contains only the needed part of anyconnect (the VPN client, without the other peaces).
We face problems with the detection of the update server, too. After disconnecting the "Cisco AnyConnect Socket Filter" the update server is reachable and the macOS updates can be run.
  • March 8, 2022
That sounds more like a Cisco problem than a Mac problem.
