I've installed BigSur on physical machine and bind it to remote LDAP server which reside behind vpn server.
The bind itself went just fine, but when I try to login or fetch any of the AD users, it fails and although the LDAP seems bounded, the AD nodes cannot be connected (all are offline)
Name State Refs Type External Locked Hidden
/Active Directory 2 X X
/Active Directory/MYSERVERDEV 11
/Active Directory/MYSERVERDEV/All Domains Offline 2 Virtual node
/Active Directory/MYSERVERDEV/Global Catalog 2 Virtual node X
/Active Directory/MYSERVERDEV/myserverdev.com Offline 16 Virtual node X
/Configure 1 X X
/Contacts Online 3
/LDAPv3 1 X X
/Local Online 2 X X
/Local/Default Online 6 X
/Search Online 5
from the logs I could see that the opendirectoryd keep trying to connect the nodes but they remain offline. I wonder if there's any timeout for the connection or anything else that can effect the connection, since the bind itself did work successfully. any ideas ?
[com.apple.opendirectoryd:session] /Active Directory/MYSERVERDEV/All Domains nodestate:
starting check
failed to create connection
opendirectoryd: [com.apple.opendirectoryd:session] /Active Directory/MYSERVERDEV/All Domains
nodestate: next check in 30 seconds
nodestate: is still offline
[com.apple.opendirectoryd:session] /Active Directory/MYSERVERDEV/myserverdev.com
nodestate: starting check
service discovery: timed out after 5 seconds
nodestate: next check in 15 seconds
