block the device if it is not up to date
  • October 24, 2020
  • 4 replies
  • 21 views
Hi, I'm looking for a script that blocks computers that are not up to date.
Best regards
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • October 25, 2020
Can you give more detail? Blocks them from what? And what specifically needs to be up to date? The macOS? An application? All applications?
dlondon
  • October 26, 2020
Do you mean something like a Conditional Access system based on e.g. Intune?
ThijsX
Forum|alt.badge.img+20
  • Employee
  • October 26, 2020
@gbourse Depending on type of organisation, but if you work in a informal one check out the following blog from @mikevos https://www.jamf.com/blog/not-forcing-updates-kinda/ it will make you laugh
mikevos
  • October 27, 2020
Thanks for the mention @txhaflaire :)
If this interests you @gbourse , you can find the setup on my github.
