Hi
i will appreciate if someone will be able to help with that.
Our security department required to block network bridge between WiFiEthernet or two Ethernet connection at the same time equally. i found script here at jamf ( airport.sh) that working great only when switching between WiFi to Ethernet and bi-directional. the problem is that once we are connect with two Ethernet networks it doesn't block the second Ethernet. so at that scenario the bridge network is available.
what do i need to add to the script? how can i preferred only one Ethernet device to be active?
here the script:
!/bin/bash
Some variables to make things easier to read:
PlistBuddy=/usr/libexec/PlistBuddy
plist=/Library/Preferences/SystemConfiguration/NetworkInterfaces.plist
Find out how many Interfaces there are
count=networksetup -listallhardwareports | grep Hardware | wc -l | tr -s " "
echo "Found$count network interfaces"
Get Interfaces
reset counter
counter=0
while [ $counter -lt $count ] do interface[$counter]=$PlistBuddy -c "Print Interfaces:$counter:SCNetworkInterfaceType" $plist let "counter += 1"
done
Get Real Interfaces
reset counter
counter=0
while [ $counter -lt $count ] do bsdname[$counter]=$PlistBuddy -c "Print Interfaces:$counter:BSD Name" $plist let "counter += 1"
done
Build Airport Array ${airportArray[@]} and Ethernet Array ${ethernetArray[@]}
reset counter
counter=0
Check for Airport
if [ "${interface[$counter]}" = "IEEE80211" ] then
Add it to the Array
airportArray[$counter]=${bsdname[$counter]} fi
Check for Ethernet
if [ "${interface[$counter]}" = "Ethernet" ] then
Add it to the Array
ethernetArray[$counter]=${bsdname[$counter]} fi
let "counter += 1"
done
Tell us what was found
for i in ${ethernetArray[@]}
do echo $i is Ethernet
done
for i in ${airportArray[@]}
do echo $i is Airport
done
Check to see if Ethernet is connected
Figure out which Interface has activity
for i in ${ethernetArray[@]} do activity=netstat -I $i | wc -l if [ $activity -gt 1 ] then echo "$i has activity..." checkActive=ifconfig $i | grep status | cut -d ":" -f2
Ethernet IS connected
if [ "$checkActive" = " active" ] then echo "$i is connected...turning off Airport"
Turn off Airport
networksetup -setairportpower ${airportArray[@]} off echo "Airport off" exit 0 fi if [ "$checkActive" = " inactive" ] then echo "$i is not active" fi fi
done echo "Checked all Interfaces"
If the script makes it this far assume Ethernet is not connected.
Turn on Airport
networksetup -setairportpower ${airportArray[@]} on
echo "Airport on"
thank you
I suspect applying ifconfig en# down to any non-primary ethernet interface would do the trick, albeit with side effects related to failover. However, why are you trying to stop bridges via script? I just block the sharing prefpane with a configuration profile to prevent their being created. If you are imaging clients, you also have the option of tampering with /System/Library/PreferencePanes/SharingPref.prefPane/Contents/Resources/servicelist.xml in the image.
Hi can you explain how to apply your solution with Jamf Pro?
thank you
