Bluetooth Device Management - Restrict/Allow
  • Feb 23, 2022 5:08 PM UTC
  • 458 views
MakeItSo
Hi All!
Prior to my current role, Bluetooth restrictions seemed to be all or nothing. Either users were free to connect to various Keyboards, Mice and Headsets or not at all.
Now I have a mandate to allow specific, vendor approved Keyboards, Mice and Headsets...but nothing else via Bluetooth.
What is your preferred method of managing BlueTooth devices in macOS/Jamf?  BlueTooth must be enabled but not discoverable and auto-pairing/file transfer type functionality needs to be disabled. 3rd Party Product? Config Profile? Script? Some combination of the 3?
YanW
  • Feb 23, 2022 9:14 PM UTC
I'm currently working on this. I can't figure out how to just allow specific vendor/device to connect. The only way I found so far is to disable bluetooth with <key>DisableBluetooth</key> <true/> in com.apple.MCXBluetooth then, turn on when the user need to pair a new device but that's no ideal in our environment.
I'm using this to turn off Bluetooth Sharing. It doesn't disable it though.
#!/bin/sh currentUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }') btSharing=$(sudo -u "$currentUser" defaults -currentHost read com.apple.Bluetooth PrefKeyServicesEnabled -bool false) if [ $btSharing = "1" ]; then sudo -u "$currentUser" defaults -currentHost write com.apple.Bluetooth PrefKeyServicesEnabled -bool false fi exit 0
Turn off bluetooth if is on.
#!/bin/sh ## 1 is ON, 0 is OFF btStatus=`defaults read /Library/Preferences/com.apple.Bluetooth ControllerPowerState` if [ "$btStatus" = "1" ]; then sudo defaults write /Library/Preferences/com.apple.Bluetooth ControllerPowerState -int 0 && \\sudo pkill bluetoothd fi exit 0
YanW
  • Feb 24, 2022 2:49 PM UTC
Correction: com.apple.MCXBluetooth plist will completely disable it. The Configuration Profile Bluetooth Restriction will keep the paired devices but can't pair any new ones.
  • Oct 26, 2023 11:06 PM UTC
Since this topic just came up in my org, it's worth noting that Jamf Pro 10.50+ and macOS Sonoma will now have payloads to disable Bluetooth Sharing.
Slight build on @YanW 's EA above:
#!/bin/bash # return current status of Bluetooth Sharing # Bluetooth Sharing must have been previously enabled for this to return any numeric value regardless of current status # otherwise, a non-zero value will be returned: # # The domain/default pair of (com.apple.Bluetooth, PrefKeyServicesEnabled) does not exist currentUser=$(stat -f%Su /dev/console) state=$(sudo -u "$currentUser" defaults -currentHost read com.apple.Bluetooth PrefKeyServicesEnabled) if [ "$state" = "1" ]; then status="Enabled" elif [ "$state" = "0" ]; then status="Disabled" elif [ -z "$state" ]; then status="Never Enabled" fi echo "<result>$status</result>" exit 0
Tested on 12.7 - 14.1.
