Build a Computer Information script for your Help Desk
  • Aug 29, 2018 2:50 PM UTC
  • 80 replies
  • 736 views
Show first post
@emily
Very nice info! Have you tried it? Trying to get the custom logo to work, but not sure how to make it work.
emily
  • May 5, 2021 2:25 PM UTC
@fredrik.virding I haven’t used it myself yet but I can try to tuck aside some time this week and see what I can come up with. The Mac Admins Slack may be another good resource for tip or some feedback on how to use it.
@emily
Noted! The rest of the features was pretty straight forward. Super slick.
  • Apr 25, 2024 9:11 AM UTC
Hello everyone,
I'm new to scripting and this helpdesk script is really great.
On the other hand, I would like the Mac address to be found in addition to the IP address when this command is used.
networkServices=$( /usr/sbin/networksetup -listallnetworkservices | /usr/bin/grep -v asterisk ) while IFS= read aService do activePort=$( /usr/sbin/networksetup -getinfo "$aService" | /usr/bin/grep "IP address" | /usr/bin/grep -v "IPv6" ) if [ "$activePort" != "" ] && [ "$activeServices" != "" ]; then activeServices="$activeServices\\n$aService $activePort" elif [ "$activePort" != "" ] && [ "$activeServices" = "" ]; then activeServices="$aService $activePort" fi done <<< "$networkServices" activeServices=$( echo "$activeServices" | /usr/bin/sed '/^$/d')
After several hours of searching, I can't find the solution so I'm asking you for help.
  • May 2, 2024 10:04 AM UTC
Hello everyone,
I finally found a solution. Here is the modified script :)
networkServices=$( /usr/sbin/networksetup -listallnetworkservices | /usr/bin/grep -v asterisk ) while IFS= read -r aService do activePort=$( /usr/sbin/networksetup -getinfo "$aService" | /usr/bin/grep "IP address" | /usr/bin/grep -v "IPv6" ) if [ "$activePort" != "" ] && [ "$activeServices" != "" ]; then ipAddress=$(echo "$activePort" | /usr/bin/awk '{print $3}') macAddress=$( /sbin/ifconfig | /usr/bin/grep -B2 "$ipAddress" | /usr/bin/awk '/ether/ {print $2}') activeServices="$activeServices\\n$aService $activePort MAC: $macAddress" elif [ "$activePort" != "" ] && [ "$activeServices" = "" ]; then ipAddress=$(echo "$activePort" | /usr/bin/awk '{print $3}') macAddress=$( /sbin/ifconfig | /usr/bin/grep -B2 "$ipAddress" | /usr/bin/awk '/ether/ {print $2}') activeServices="$aService $activePort MAC: $macAddress" fi done <<< "$networkServices" activeServices=$( echo "$activeServices" | /usr/bin/sed '/^$/d')
