Hi all,
Is there an easy way to do bulk edits on the puchasing part?
On a smart group for example.
Thanks
Yes, if you are trying to update laptops. No, if you are trying to update iPads. You can update the GSX information by completing an action on the smart group. That assumes you have a GSX account. The feature is broken with iOS devices. You might be able to do that with the MUT if you don't have a GSX account.
