Can't Bypass the Secure Token Window when logging in
  • June 14, 2019
  • 51 views
Hi All,
I am working on the workflow for deploying 10.14.5 to our machines and while testing the desktop workflow, keep getting this
I searched earlier and found the solution of adding a custom config profile with com.apple.MCX as the domain and "<key>cachedaccounts.askForSecureTokenAuthBypass</key> <true/>"
as the main entry in the plist. However, after trying this twice, it still prompts me for a secure token for each user that logs in. Am I missing something?
Thanks
Best answer by tomhastings
Could it be a problem with the plist file you uploaded?
I set this as the only payload in a configuration profile and it works great.
  • June 14, 2019
  • June 14, 2019
This is the content of my plist:
"<?xml version="1.0" encoding="UTF-8"?>
<plist version="1.0"> <dict> <key>cachedaccounts.askForSecureTokenAuthBypass</key> <true/> </dict>
</plist>"
and here is what it shows in the config profile:
  • June 14, 2019
And just realized from looking at our screenshots, that I added .plist to the domain. That fixed it. Thanks for the help @tomhastings .
