Hi All,
Wanted to update my Quickadd package after the 8.1 update, but I'm getting this error, any ideas? I was able to create it on 8.0 under the same user without issues…
Thanks,
![external image link](attachments/da13fabfb54b45b78c1381867d3cc085)
Matt Bezzo
IT Technician
HackerGroup
t 206.805.1500
d 206.805.1303
http://www.hackergroup.com<http://www.hackergroup.com/>
BE GREEN. USE YOUR SCREEN.
Are you logged in with an AD-based account?
I got this as well. Logged in with a local admin-class account and it was fine.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
Casper 8.0 will auto update the binary when checking into the server. So technically you should be able to keep your 8.0 and it will auto
update to 8.1 if found on your server.
![external image link](attachments/03fa4e51526046f99b971ad06d0d7ab0)
The error seems to be generated from having a longer user ID on the account.
Tom Tubbiola
Design IT
Ttubbiola at oakley.com
949.900.7705
E.g. From a directory service.
Jared F. Nichols
244 Wood Street
781.981.5436
+1
Make sure the account in the quickadd (if you're creating one) is a local account too. I.e not a directory account.
Regards,
Ben.
Okay, thanks all. I am AD bound, will try from the local account.
Matt Bezzo
IT Technician
HackerGroup
t 206.805.1500
d 206.805.1303
Just tried this with the 8.2.1 version of Recon and it still fails on a domain account.
Tom Tubbiola
Design IT
949.900.7705
