Can't mount distribution point
  • October 1, 2018
  • 5 replies
  • 7 views
Good Morning,
I have dug through the forums without a definitive answer to this, but has anyone came across a new solution?
As of last week, I haven't been able to execute policies due to this error.
Weare on version: 10.5.0-t1527689731
Thank you
  • 11 replies
  • October 3, 2018
No-one?
mark_mahabir
Forum|alt.badge.img+15
  • 337 replies
  • October 3, 2018
Are you using an SMB DP? Are you able to switch to an HTTPS based DP instead?
Did you try any suggestions in this thread?
Hugonaut
  • 574 replies
  • October 3, 2018
This has happened to us a few times. I literally remap everything
The following is what I have done to resolve.
  • confirm your Share Repo is in the right spot on your JSS Server, also, right click & get info / check sharing permissions
  • Check Read Writes Accounts on your JSS Web interface, Make sure they match the Servers R/W Accounts.
  • Go to JSS Server
  • System Prefs -> Sharing -> File Sharing -> SharedRepoFolder ---- Remove it
  • Go to R/W users and reset the password
  • Add share back to File sharing & add the users again
  • On JSS Web interface (Settings->ServerInfrastructure->File Share Distribution Points)
  • Make sure Server url is correct & set to Master Distribution Point
  • Add the users and new password again
  • Make sure share name is correct, AFP, Port 548 (SMB is blocked by every firewall) -- Double Check Everything
-- Boot server
if all else fails, make a totally new file share distribution point on your JSS Web interface & remap everything on the server & web interface again. (again make sure to set as master distribution point)
IF THAT FAILS - make a jamf support ticket haha
  • 11 replies
  • October 4, 2018
Thank you very much Hugonaut! Reading through now :)
  • 391 replies
  • October 4, 2018
more info required...
Server OS?
SMB or AFP share?
seriously, are you running 10.5??
cheers
