Hey there,
we an environment working with casper suite and I am trying to add a mac with OS X El Capitan 10.11.1...trying to install quick add.pkg via terminal I get the following error message:
*:~ support$ sudo installer -pkg QuickAdd.pkg/ -tgt / -verboseR
Password:
installer: Package name is QuickAdd
installer: Installing at base path /
installer:PHASE:Installation vorbereiten …
2016-03-08 15:48:06.913 installer[1459:50326] Package /Users/support/Desktop/QuickAdd.pkg uses a deprecated pre-10.2 format (or uses a newer format but is invalid).
installer: The install failed (Das Installationsprogramm hat keine Software zum Installieren gefunden.)
I am very new to the casper suite topic. Has anybody any experiences with adding OS X 10.11.1 systems ?
Thank you very much in advance.
Best,
André
