JSS 8.73, Casper Admin running on 10.6.8 Xserve. 12 Mac OS DP's, manual sync as needed, not auto.
I'm recently noticing that when I perform a DP sync with Casper Admin, it's glacially slow. 10.9.2 update didn't complete to even the first DP overnight.
However; if I log into the JSS, mount the CasperShare of a DP and do a simple drag-n-drop file copy- it completes in normally reasonable amount of time.
I was going to complain to the network guys, but I get normal throughput manually. Anyone?
