Casper Admin will not mount DP in 10.9
Show first post
Chris_Hafner
Forum|alt.badge.img+29
Strangely, I'm experiencing the opposite symptom from freddie.cox Casper admin won't mount the SMB share for the primary DP via SMB. If I change it to AFP it mounts just fine and will replicate to either AFP or SMB shares. Switching back to SMB causes the error again. Hate to say it but I'm not sure this one is completely solved.
Chris_Hafner
Well, here's what I found. Deleting
/Library/Preferences/com.apple.AppleShareClient
resolved my issue. Something must have kurfuffled at some point in the past.
  • November 15, 2013
@Chris_Hafner - I just checked and I don't have that same plist. However, we just completed the upgrade to 9.21 from 8.73 and I am now able to sync all my DP's (SMB or AFP) from my Maverick's install without any issue.
Once again, thanks to the Nation for jumping in to help! (Even for the sarcasm!)
Chris_Hafner
Good to hear! Though, that file may not exist in 10.9 with the "server" app. I just got the servers to finally stop doing stupid things after upgrading them to 10.8 so I'm leaving well enough alone for just now ;-)
  • November 25, 2013
We also had this issue since we upgraded to 8.73.
We had a special character (an @) in the read-only CasperShare AFP share password, and jamf binary always failed to mount the share in 10.9. The problem did not exist in 8.6.
After digging with "sudo newproc.d", I noticed that on 10.8, the password was not passed on the command line to mount the share, so this is why it continued to work : /sbin/mount_afp -i -o nobrowse afp://myuser@server:548/CasperShare /Volumes/CasperShare
On 10.9, the password was passed on the command line, and obviously failed to interpret the double "@@" (password was similar to "PaSsWoRd@") :
/sbin/mount_afp -i -o nobrowse afp://myuser:PaSsWoRd@@myDPname:548/CasperShare /Volumes/CasperShare
Somehow, it also failed with a "!" special character (don't ask me why, maybe it worked but we were in rush to fix issue after 8.73 upgrade), and we had no other choice than to change the password on 45 DPs :-((((
  • November 25, 2013
If the passwords are being passed on the command line and are not being quoted, the shell is interpreting them before passing them to the mount_afp command. Some special characters would certainly have meaning to the shell and thus be stripped out and interpreted, so the resulting password string given to the mount_afp command would be incorrect.
We are seeing this exact same problem with our 10.9 clients running 8.73 CasperSuite trying to access a 10.6.8 server. This "special character in the password" possibility never crossed our mind until this thread came up. Unfortunately we in the Federal Government space have enforced password requirements that mandate at least one special character in the password so JAMF will have to resolve this or we will have to figure out how to upgrade our 10.6.8 Apple Server to OS X 10.9 and CasperSuite 9.x.
  • January 14, 2014
Removing an @ character from my password resolved the issue for me. Running 10.9.1 on the DP and Casper Admin client, JSS 8.73
  • January 23, 2014
@sbrosnihan can you provide further details on all the steps you had to do to change the password? We have a password with a special character and I would like to test this. Did you just change the casperadmin user's password in the DP's File Sharing tab? Also need to change it in System Preferences?
  • January 23, 2014
I reset the password in the users section of sever.app and on the JSS in the DP's sharing tab.
  • March 27, 2014
I'm not a User of this software but I found this post in searching for the same issue with special characters in my AFP password. Basically you have to encode them, i.e. @ = %40. You can find the applicable URL encodings here:
http://www.w3schools.com/tags/ref_urlencode.asp
- source: http://www.opendoor.com/shareway/pro/ug/afp_urls.html
Special characters in AFP URLs AppleTalk names and zones, and Macintosh volume, folder and file names often contain characters not normally found in URLs. These characters include spaces, slashes and high-bit ASCII characters (such as those used for international characters). AFP URLs should encode these special characters using the %xx construct (for instance, %20 for space). In many cases Macintosh browsers will understand URLs which contain special characters, but it is especially important to encode slashes (%2F) which otherwise will be used as directory delimiters.
  • April 23, 2014
Just want to confirm what @sbrosnihan and @epardee said...
Having an @ in your password on your DP mac will cause it not to mount through Casper Admin. You can mount manually but not through admin. What a pain that was. Now it replicates fine. Thanks again.
  • July 30, 2014
So I'm basically having this issue. I get the same result as freddie.cox does except that I'm using SMB from a 2008 R2 server.
Changing the password does not address this issue.
Mine has an interesting twist in that I can use these just fine on the network where my JSS resides, but on VPN I'm not able to. Our VPN joins the same subnet I would be in if I were at the office. My client sites report the jss just fine as well.
Any thoughts?
We faced a similar issue.
Casper Admin 8.73 could not mount Casper Share via AFP from Casper 8 DP under OS X 10.9.x.
Same scenario worked under OS X 10.8.x
A local folder "CasperShare" was created in /Volumes but then Casper Admin just stalled.
We had a slash "/" in the password. After we got rid of that, mounting works as expected.
  • April 26, 2016
Just chiming in that the "Deploying OS X v10.7 or Later with theCasper Suite" PDF is much better than the above steps, because it pre-caches the huge install file, rather than having the user sit there and wait for it to download via Self Service.
Also, one note. When you copy the .app from /applications from /users/shared, you need to use copy/paste, rather than drag & drop. I found that OS X was creating an alias instead of moving the file, and when dragging that alias to Casper Admin 9.91, it would crash Casper Admin with a NPE.
