Hello,
I wanted to get playing with Casper Focus as I think it will help a bunch of our labs. However when I install Casper Focus on the iPad I login with my test account which is setup to have a class of iPads that are in a mobile device group. But it says there are no classes available for me to interact with. I'm not sure what is wrong.
EDIT: I figured it out. I was using the 8443 port with http. Oddly it connected but wouldn't give classes.
Jonathan,
Can you verify that the meeting time(s) for the class are not outside of the scope of the day/time when you are attempting to use Casper Focus? Casper Focus will not allow you to interact with classes that are not currently meeting.
Nick
Having the same issue I have meeting times set.
I cant get connected using https;//my server:8443 but i can connect using http://myserver:8443 also getting alot of Could not login if a try again i get logged in but with no classes available.
just got working i need to go to the http://myserver::9006 port
