A number of our staff are reporting issues with capser focus not allowing them to remove focus from an app.
This usually occurs when the WIFI connectivity is for some reason lost, all iPads in a case use the same SSID but it is only a couple that seem to drop the WIFI.
We use Meru AP's around school, does anyone have any ideas?
I think having a setting that allowed the iPads to automatically disable focusing of an app at the end of each period, so for instance 9am-9:59am then when 10am arrived all focused apps would be dropped ready for the new session to commence.
Any help would be great.
Thank you in advance
Be the first to reply!
