Since upgrading to 9.81 Casper Imaging will not run if we have our Adobe CC Package in the build train. The Defect is D-009846. It is not publicly documented anywhere. If you are using Casper Imaging 9.81 and get stuck at either the Temporary Adobe Account or Casper Imaging splash page and have Adobe CC in your build train it is most likely this bug. Please reach out to your TAM and let them know.
Hi @MacMiz
Which specific Adobe products? I'm able to include Adobe Creative Cloud products as part of my imaging configuration without an issue.
I'm using CCP and not AAMEE.
Also, point of clarification: AAMEE was for Creative Suite; CCP is for Creative Cloud. Is the problem being experienced with Creative Cloud products or with the older Creative Suite?
Creative Cloud. JAMF has verified the bug started with 9.8.
