Casper imaging can't mount distribution point, but I can mount distribution point with mount command
  • February 23, 2015
  • 39 replies
  • 196 views
Show first post
  • March 7, 2015
We haven't encountered this issue with Imaging but we are having a related issue mounting DPs when replicating after upgrading to 9.65. Casper Admin is able to mount the Master DP but some of our DPs fail at mounting attempt. Upon monitoring the /Volumes directory on multiple clients running Casper Admin I noticed that the mount point appears to be created and the share is mounted but Casper Admin fails with the same error as the OP.
These issues are related. After changing the problem DPs address from hostname to IP in the JSS replication will work.
  • March 10, 2015
As another data point, I was having issues. Luckily we were about to deploy a new JDS anyway. Once the JDS was set up, I verified that it was communicating with the JSS. I already had a cache of the packages on a hard drive so I copied those over and did an inventory. No problems connecting to it. Switched it to the master and it has been 100% stable for the past week. This was a completely clean installed starting with 10.10.2 and JDS 9.65. Our old JDS is currently offline. I do intend to wipe it out and start fresh on it as well to see if there are any replication issues.
  • March 18, 2015
Taking $ out of the password fixed mine.
  • March 24, 2015
Removing the $ from the password solves the problem.
  • March 24, 2015
Removing special characters from passwords is a known workaround for previous versions, however in my (and others') case(s), I have already done this and still have the mount issues. For now, I am using the 9.63 app as it works fine with my 9.65 JSS.
  • March 25, 2015
We have special characters in our passwords other than / $ and :
We are still having issues mounting the distribution point. It seems like it mounts but then it has problems unmounting the volume for the DP. So the next time you try to mount the DP, it would fail.
For those having issues mounting your DP, can you check to see if you have that volume showing up when you run the following command from terminal:
sudo ls -al /Volumes/
erikstam
  • March 25, 2015
Changing the special characters in the password (in my case the "@") and using the IP address instead of the FQDN "solved" the "can't mount DP" for me.
  • March 30, 2015
Well this is kind of frustrating, I just setup a distribution point in DFS to test AutoDMG only to find out the 9.63 doesn't perform block copying, and now 9.65 won't mount the SMB correctly in netboot!
I'll have to take a look at this during this week.
  • March 31, 2015
We were able to get it to work by using the IP instead of the FDQN. Removing special characters didn't stop the unmounting issue.
  • April 6, 2015
Has anyone had any issues mounting DP with 9.7?
jyergatian
  • April 6, 2015
I'm using 9.7 and having no issues mounting my JDS instances from an AutoCasperNBI. I've tested our OS X and RHEL7 JDS instances. Passwords are beyond me - I've kept the random passwords generated at install.
  • June 16, 2015
Recently setup a new 9.72 JSS with Windows SMB DP's. Seeing the same phantom mounts that "Fail" to mount then we have to manually unmount and then try again and sometimes it works sometimes it doesn't
Not seeing this issue on a 9.63 that was being used on the same network.
Anyone ever find anything on this?
  • June 16, 2015
See if this applies to your situation....this prevented me from upgrading production from 9.63 to 9.72: https://jamfnation.jamfsoftware.com/discussion.html?id=14233#responseChild89283
  • October 21, 2015
Hi All
For those using Windows DP's
@Suggett Re: Could not mount distribution point
https://jamfnation.jamfsoftware.com/discussion.html?id=10178
