Any tips on creating a Casper NetInstall image? I'm using their
NetInstall Image creator 2.02.
I was hoping this tool would be build a NetInstall image similar to how
NetRestore does, but this doesn't seem to be the case. Building my Casper
install image off of a fairly basic 10.5.6 image results in a NetInstall
image that is 9+ gigs in size. I was hoping for something much smaller. Maybe I'm doing something wrong...
Chad
Hi all,
I posted this in the Resource Kit mailing list too, but I'm not sure if it
went through or not...
Anyone played with the 3.1 beta of the new Casper NetInstall Creator? www.jamfsoftware.com/downloads/CNIC-3.1b.zip
I'm getting an error message when it launches Casper Imaging and it just
keeps trying to re-launch.
I've ensured that I gave it the right DNS name and/or IP address, but it
keeps telling me
Reading Preferences...
Checking Serial Number...
Relaunching Casper...
Then sometimes it will give me a 'Checking https://dyld: shared cached file
was build against a different libSystem...'
And that's all I can read. There's another whole line to the error message
though.
Then it goes to 'Looking for Autorun Data/PreSage on JSS...' like it's going
to start up, but then the cycle restarts.
Any ideas/help? Anyone else tried or seen this?
Thanks,
Bob
Not sure if it will fix it, but they dyld issues can be resolved by doing
sudo update_dyld_shared_cache
j
I just tryed using CNIC3.2 and got an error "AppleScript Error ditto can't get real path for source (1)". Has anyone else see this error
