Hi all,
I've been searching through JAMFNation for an answer, but haven't found one that exactly answers my query.
I'm trying to use Casper Remote to remotely log onto a Macbook. We are using Casper 9.96. When trying Casper Remote, it firstly goes to "Opening SSH Connection to <IP Address>", then after around 10 seconds, it goes to "SSH is not enabled on the remote computer".
My end goal is, obviously, to remote to a Macbook and screen share with the user. This will make my support work much easier. But how do I achieve this? Is there a particular setting on the Macbook that needs to be activated? Very sure the Casper remote can see the Macbook, because it actually identified the correct IP address.
