I can only download Composer. I would like to download Remote. What do I need to do in order to have access to Remote?
Are you a full Jamf Pro customer? If so, see if your JamfNation account is linked to your organizations Jamf license. Under your account icon in the upper right corner here in Jamf Nation, select My Assets. Within there, assuming it is linked to your org, you will see the full Jamf Pro downloads. Use the one for Mac and it will include all the local Mac applications that come as part of the product.
If you don't see it there, then you may need to reach out to Jamf support and explain your situation to them, and they can help you get it linked up. This usually is because the company email address under your Jamf Nation Profile is not set correctly.
Hope that helps.
