Hello!
I'm wondering if there's any way to change what application opens a given
type of file. In my specific case, I'd like to set either Adobe Reader or
Preview to open pdfs, instead of Adobe Acrobat.
So far as I can tell, this is controlled on a per-user basis in the
~/Library/Preference/com.apple.LaunchServices.plist file. I don't entirely
understand the structure of the file, but it looks as if the only way I can
think of doing this is writing a script that walks through the file, finds
the reference to pdf files, changes to Preview/Reader, or else failing to
find such a reference, adds it. Is there another, more elegant, way of
doing this?
George M. Casper
Tech Support Specialist
Bucknell University
"People believe any quote they read on the internet if it fits their
preconceived notions." - Benjamin Franklin
