Changing preferred Wifi networks without admin rights?
  • November 13, 2018
  • 18 replies
  • 735 views
We’ve recently removed admin rights on Macs for all of our users. Does anyone know of a way to enable users to always be able to administer preferred/saved Wifi networks which are saved on their machines without having to grant them temporary admin rights?
Best answer by dsavageED
Maybe try:
# Workaround as shown in https://www.jamf.com/jamf-nation/discussions/19050/add-wifi-networks-without-admin-privileges
# Allows non-admin users to add printers and manage their WiFi configuration.
#For WiFi
/usr/bin/security authorizationdb write system.preferences.network allow
/usr/bin/security authorizationdb write system.services.systemconfiguration.network allow
#For printing
/usr/bin/security authorizationdb write system.preferences.printing allow
/usr/bin/security authorizationdb write system.print.operator allow
/usr/sbin/dseditgroup -o edit -n /Local/Default -a everyone -t group lpadmin
/usr/sbin/dseditgroup -o edit -n /Local/Default -a everyone -t group _lpadmin
exit 0;
mark_mahabir
  • November 13, 2018
We use a script mentioned in this thread to allow users to set preferred networks in Self Service.
Does that help at all?
dsavageED
  • November 13, 2018
Maybe try:
#For WiFi
#For printing
exit 0;
  • November 14, 2018
@dsavageED - That worked perfectly, thank you!
Maybe try:
#For WiFi
#For printing
exit 0;
Is this still valid for macOS 12.3.1? I just tried it and while networking is now indeed unlocked it will ask me for admin logon when I hit OK. The changes wont stick without it.
I'm seeing the same issue; the networking pane is unlocked, but when I choose a Wi-Fi networks and hit the minus "-", it asks me for admin login.
It does work, it just needs the
/usr/bin/security authorizationdb write com.apple.wifi allow
line in it too.
  • December 1, 2022
May be a dumb question, but I assume this is just a "run once per machine" deployment, or do we need to stick it in self service to be run on demand
I run it "once per machine".
line in it too.
Did that, policy ran ok with below results but making changes to WiFi STILL asks me for admin credentials.
[STEP 1 of 4]
Executing Policy System Preferences - Print and WiFi without admin
[STEP 2 of 4]
Running script System Preferences - Print and WiFi without admin...
Script exit code: 0
Script result: YES (0)
YES (0) YES (0) YES (0) YES (0)
[STEP 3 of 4]
[STEP 4 of 4]
[STEP 1 of 4]
[STEP 2 of 4]
Script exit code: 0
[STEP 3 of 4]
[STEP 4 of 4]
Well, well, the test machine I have is Ventura 13.01, and indeed, it is now asking for admin credentials. Looks like we'll need another solution.
This is how Apple keeps us entertained.
  • December 14, 2022
Not sure if this is relevant but I added /usr/libexec/airportd prefs RequireAdminNetworkChange=NO RequireAdminIBSS=NO before testing
While testing on Ventura, I found that I'm prompted for the admin password, but I click Cancel and the removal still works. Curious if you get the same result.
  • February 8, 2023
does anyone know how to reverse the script so it's back to being admin locked?
I believe you will have to delete the preferences you made changes to in order to get it back the way it was.
Anyone has found or written a script to allow user changes for WiFi settings for Ventura?
I'm struggling to allow this on MacOS Ventura as well.
Anyone found a solution?
  • October 11, 2023
i have rearranged the code to only allow the 'Activation W-Lan Management Settings'
Maybe try this:
# Allows non-admin users to manage their WiFi configuration.
#For WiFi
exit 0;
9GqPZD
  • October 27, 2025
Has a better solution been found for this or is the script still the best way?
Josh-Q
  • October 27, 2025
@9GqPZD I believe this is still the way. Seems to still be working on our macOS 26 deployments.
