Is there a step by step guide to configure classroom for mac? Its working flawlessly on our iOS devices, but the mac's come up with a blank classroom.
Do you use ad-hoc method for classroom on iOS? If you do, the classroom don't transfer/appear on the Mac. You must create them manually again and they don't sync between iOS and macOS.
Each teacher needs to setup a class per period, choose add students and wait for students to join (and then approve). I'd also recommend adding a configuration profile with (see attached) so they can't leave the class without teacher permission.
The old way of doing for teachers is over. They can do it themselves.
If you are trying to use classes imported from ASM you need to be sure that the local user account matches the AD user name in Jamf, for example:
local jamf
ryanjenkins != ryan.jenkins
You might find some more useful information here.
I also found that the MDM user on the machine had to match the username of the teacher associated with the class.
In my case all iPads are registered to staff and students by their email address. That all works fine. For a staff member to also be able to use their 10.14 running Mac and get classes automatically through the JSS/ASM their MDM Username (this would be the Account Name under ADVANCED OPTIONS in Users & Groups or RecordName of that person according to dscl) would also have to be their email address. I was allowing my staff to setup their own accounts through DEP when receiving their Macs and since that didn't match what was already setup by their iPad before this didn't work for me either. I changed their account name, reboot couple of times, and the profile does come down.. and it works.
