Cofniguration Profiles missing when macOS was --eraseinstalled
  • January 13, 2022
  • 0 replies
  • 15 views
We erasedinstalled the macOS from HighSierra to Big Sur and after the reinstall not all the configuration profiles were installed again. We only had MDM Profile, Privacy Preferences, Jamf Notifications, System Extensions and Dock. The WiFi profiles and certificate profiles and few others were missing. Renew MDM Profile command didn't help. We had to use RemoveMDMProfile from Jamf and then run Recon.app and then ran 'jamf manage' even then the profile will not flow and then finally we had to run the command 'jamf deleteSetupDone' and restart the computer which then brought all the configuration profiles. Quite painful experience.
