com.apple.fonts not accessible on Monterey/M1 pro
  • Nov 5, 2021 6:06 PM UTC
  • 31 replies
  • 467 views
Show first post
How did you scale it to deployed macs? pushed the new cert to all macs?
We just have a single Mac that we deploy to, so I VNC-ed in and updated it manually via keychain. You have many mac build machines? Do you use some kind of image?
Edit: I just realized I didn't even know what jamf is, just arrived here because of the similar error. You may have to delete the old certificates, as well.
  • Aug 10, 2022 5:23 PM UTC
I found that the fontd daemon wasn't running - so ran
launchctl load -w /System/Library/LaunchAgents/com.apple.fontd.useragent.plist
which fixed it.
Giannini
  • Oct 21, 2022 1:37 PM UTC
I've only started looking today, but I've found several open threads concerning this problem:
What I'm noticing is some discussion about secure tokens from the Apple Developer Forum threads. In one example someone was trying to load a Launch Daemon to have software updates install, but it also encountered a hung state that reads (to me) similarly to the symptoms mentioned in the MunkiTools thread. It seems like the connection between com.apple.fonts and Software Updates are the notifications presented to the user when the sequence is started and/or ready to restart. There are a lot of mentions of Secure Tokens being an issue, and while I didn't think of that at first, that seems as good a place as any to start. If I come up with anything on that front I'll share it here.
in replying to @The_Black_Rose i'm having the same issue with Monterey 12.3 wanting to upgrade to 12.6 via terminal using the softwareupdate command and it didn't work, i also got the error message below
softwareupdate[17905:571877] XType: com.apple.fonts is not accessible.
i don't think this is related to secure token because i ran the following command:
sysadminctl -secureTokenStatussysadminctl -secureTokenStatus localadmin and it returned:
Secure token is ENABLED for user localadmin
so as you can see, it's not that but Since Monterey apple have definitely broken the softwareupdate comand!! The only way i could update from 12.3. to 12.6 was via the usual UI update tool.
michael_madsen
I was having a similar issue with a custom app that pushes a local notification. It was working fine when I ran the script locally, but as soon as it was run by Jamf, it failed with this XType error.
The problem was that the custom application was run in root context. The fix is to run it in the users context:
sudo -u "$CURRENT_USER" open -a "$NOTIFY_APP" --args "Software Update Notification" "$applicationName needs to be updated!"
  • Nov 28, 2022 6:07 AM UTC
Thanks I will try this!
HARTE QUIMBY | ASSOCIATE DESKTOP ENGINEER
My SLEEP NUMBER® setting is 40. What’s yours?
P 763.551.6284
harte.quimby@sleepnumber.com
SLEEP NUMBER
1001 Third Avenue South, Minneapolis, MN 55404
sleepnumber.com | facebook.com/sleepnumber
  • Jan 27, 2023 3:07 PM UTC
This worked for me too!!! Thank you for the suggestion.
The thing that I think finally solved it was installing the correct "Apple Worldwide Developer Relations Certification Authority" in Keychain. The one I had had an expiration date of February 2023. I deleted that one and went here: https://www.apple.com/certificateauthority/, downloaded the one called "Worldwide Developer Relations - G3 (Expiring 02/20/2030 00:00:00 UTC)", then retried the build and it worked.
What method do you use to deploy the Apple certificate- Composer?
