Composer 10.28 - Couldn't communicate with a helper application
  • April 12, 2021
  • 36 replies
  • 625 views
Show first post
Zelto
  • August 18, 2023
On composer 10.49.0. This is still an issue, and the fix still works.
  • October 19, 2023
This worked for me as well!
  • October 24, 2023
Thank you! Weird how this hasn't been patched yet.
  • November 29, 2023
Thank you very much.You`ve been very helpful.
Thank you so much, you've been a great help
  • January 31, 2024
Thanks  a lot! It fixed my problem with gimp 2.10.36 (apple chips).
miniberry
  • March 26, 2024
I was having the same issue. I checked the online manual and found that they added a new Preference for executable type I found that to be causing the issue. I can only hazard a guess that it is not detecting the executable type correctly. I went into Preferences and changed "Executable Types in PKGs:" to "One or More executables require Rosetta" from "Automatically detect executable types" it fixed the error.
Oh.my.goodness, you guyss!! Thanks so much for this solution @Reiven I was having issues packaging JASP and it kept failing (hasn't happened before) and couldn't figure out what the issue was, searched for the error code and came across this thread. This fixed it! Grateful for this community. Thank you!
  • June 4, 2024
This is still an issue in composer 11, thanks for the solution.
  • June 15, 2024
Thank you for the solution
trevoredwards
  • February 19, 2025
Still an issue in 11.4.0.
Was driving me crazy. Thanks for the post!
  • November 3, 2025
Composer 11.9.1 and I needed to do this for a specific App.
