computer naming issue when replacing HD
  • October 20, 2010
  • 16 views
Forum|alt.badge.img+31
So, yet another weird quirk I found today...
I just got 100 new hard drives in for 100 Macbooks I have that are out of warranty and all have bad hard drives. I have replaced about 40 HDs today and imaged each machine. 9 times out of 10 the Macbook will come up with the wrong name in Casper Imaging. The weird part is, they are all identifying as the same computer. So every computer that boots up and pulls the wrong name from the JSS is the same computer name every time. All I did was replace the HD in them. Which should not contain any data pertaining to the asset in the JSS database.
So, like every Macbook I netboot to image comes up with the same computer name and auto run data. I have been manually changing the name to the proper naming convention (based on asset tag) and been imaging all day.
1 out of 10 times it will netboot with the new HD and pull up the proper name. Any idea what is causing this?
Thanks,
Tom
  • October 21, 2010
You're not doing something weird like using an Ethernet dongle this time around or something…
Just a thought
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
  • October 21, 2010
Nope....
Every new HD I netboot and format via disk utility always comes up in
Casper Imaging as the exact same computer name. Not really a huge pain
because changing the name is very easy, but not sure why it is doing
this.
The only Macbook Airs we have are high up directors using them. So
they aren't imaged or even managed with Casper.
