Configuration changes not being saved for Adobe installs
  • August 27, 2008
  • 7 views
Hello,
We have found some inconsistencies when dealing with Adobe installs and Casper v5.13.
In the past we made a single package for CS3 and this worked very well. However for this AY we took advantage of Casper's ability do deal with CS3 and consequently made individual packages for each app, hoping that Casper would allow us to update the suite easily. We had problems with the updating mechanism at imaging time so we abandoned updating and planned to install the version that came on the media and leave it at that. Then we had more problems with the jamfHelper app and reverted back to our original single CS3 package.
We now have the following problem:
We deleted the Adobe Installer Images from All Items | Adobe Installer Packages; they were moved to the Deleted Packages folder as expected. The trash was then emptied from Casper Admin.app and the Deleted Packages directory was empty. Saved the changes in Casper Admin.app and then quit the app. On re-opening the app the Adobe Installer Packages for CS3 had miraculously reappeared under the 'All' view type but not under 'Adobe Installer Images'. They are visible both in the JSS and the app. Obviously the software packages themselves have not risen from the dead!
At least once I have made changes using Casper Admin.app only to find they have not 'stuck' between sessions (and yes, I have saved!). This has caused some problems with our latest imaging round.
Are you aware of other users having similar problems?
Regards,
James
PS I was very tempted to change the subject line to 'Zombie CS3 installs' but...
-- James Nairn mailto:jwrn3 at cam.ac.uk
Macintosh Systems Specialist University of Cambridge Computing Service
Pembroke St, Cambridge, CB2 3QH Tel (01223 7)63486
1 reply
  • March 30, 2013
how to instalig flash player
