I am new to JAMF and my organization recently stood up an on-prem server and I am working out the management kinks so we can start applying policies to our iPads and Macs.
My problem: Whenever I attempt to set a configuration policy containing a 'restricted' payload, I get Failed Commands.
Command: Install Configuration
Error: The data couldn't be read because it isn't in the correct format.
I do not understand this error because it triggers whenever I alter the payload and whenever I leave it at the defaults. This happens if I push the configuration or attempt to apply it during device enrollment. This is a PreStage enrollment using DEP in Apple School Manager.
Everything else I tested a configuration profile with (Wi-Fi, Passcode, Single App Mode, etc.) seems to work. I even enabled and disabled the PreStage Enrollments options during my testing. However, I cannot figure out what I am doing wrong with the 'restricted' payload.
What am I missing?
Please advise.
