Connect 2.25.0 issues with Mac OS 13.5
  • July 25, 2023
  • 4 replies
  • 36 views
Apple released OS 13.5 today. We have noticed that the Connect Identity Authentication window disappears after the OS update. We are authenticating through Google.
Has anyone else experienced this? Do you have a fix?
Do you know if you're deploying the DisableRSRWatcher or DisableUpdateWatcher keys (set to false) that were introduced in 2.25?
  • July 25, 2023
We were not aware of that. We're going to make that correction and redeploy. Thank you.
  • July 28, 2023
It didn't work.
  • July 28, 2023
We deployed a bone stock M1 Mac Air from Jamf and had the same issue. The computer connects to the network initially but then loses connection and doesn't remember the password for the correct network. I'm convinced this is an Apple problem, not a JAMF or network issue. It only happens to M1 Macbook Airs and Pros. Intel MacBooks are fine, iPads are fine, and Windows machines are fine.
