connection error occured: jamf binary failed to install
Hi Guys,
Just updated to version 8.1 with the above error popping up every time I try adding a machine via recon
THOUGHTS ?
![external image link](attachments/c1fcef4daa4d455fba09407bdaa46b59)
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • 1906 replies
  • March 28, 2011
Is the JAMF binary up-to-date on the machine you're trying to inventory?
On 3/27/11 7:41 PM, "Andrew Jezard" <ajezard at shcgeelong.catholic.edu.au> wrote:
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
![external image link](attachments/e5b91d4d688c45769b0fad36dbaf5d2e)
talkingmoose
  • Community Manager
  • 1906 replies
  • March 28, 2011
Sorry, Andrew, but that was my only rabbit. I should have read your
On 3/27/11 10:09 PM, "Andrew Jezard" <ajezard at shcgeelong.catholic.edu.au> wrote:
subject better because that appears to indicate the problem is indeed with
the binary on your machine.
Is your server up-to-date with 8.1 as well? You don't want to mix versions
between the applications and the server. Open the Terminal application and
type "jamf help". Use this to get the syntax for updating your JAMF binary
from the server.
William Smith
Technical Analyst
(651) 632-1492
  • 0 replies
  • April 1, 2011
We just upgrade to 8.1 this morning and I am also having this issue with the
new Recon. I added a screen shot of the error I get. Anybody out there find
a fix for this yet?
Thanks,
Armando
![external image link](attachments/055e3e1242e14d0c9660f308f448a42b)
![external image link](attachments/377adf2d80b34ea8880f0eff069d7c49)
  • 0 replies
  • April 15, 2011
Just upgraded this morning and getting the same error. I'm sure there is a quick fix for this, I just don't know what it might be.
Thanks.
Forum|alt.badge.img+31
  • 2721 replies
  • April 15, 2011
Have you tried creating and using a new quickadd.pkg? I would try that next
![external image link](attachments/02cdbd6eb62b4525a301c9d07c5a25c9)
  • 0 replies
  • April 15, 2011
Just tried that and still no luck. Still getting the connection error: jamf binary failed to install.
  • 516 replies
  • April 19, 2011
Hi Andrew,
I had this same thing going on. I pushed out a known good binary, no help.
Was also seeing a "Bad Username pass" if I tried recon'ing remotely w/ ARD
but could SSH in no problem using the casper SSH account
Pushed out a known good /Library/Preferences/com.jamfsoftware plist- no help
RemoveFramework, rescan- no help
Quickadd- no help
Tested w/ Recon 8.0: same result
Verified "inventory Unix Executables" OFF in my JSS Inventory options: no
help
Dumped the recon report to the desktop: worked OK
Finally on the machine, opened recon w/ option and reset the
server/refreshed the plist and then it worked.
Hope this helps!
Sandy
  • 516 replies
  • April 20, 2011
I have also had a few where they seem to hang at "gathering Application
Usage" and then fail w/ "connection error", so error messages do not
necessarily reflect actual problem.
If I delete the Folder:
/Library/Application Support/JAMF/usage
then everything goes...
I'll have to check back on those to see if they'll gather that data in the
future. Seem
Sandy
Sandy (et. al.), I am getting the same error as well. It was working fine until I rebooted my Casper server. Now I get the error when trying to RECON. I am already at 8.4.3 and have deleted the JAMF/usage folder.
Still stuck.
Mike
Cookie policy
Cookie settings
