Connection failure: "The operation couldn't be completed. (Error 502.)"
  • July 10, 2019
  • 30 replies
  • 195 views
I received this error message on 5 machines this morning. I'm assuming that our policy to recon tried to run but couldn't because the user terminated their connection in the middle of it.
I just wanted to see if anybody else has seen this before.
Thanks
Executing Policy JAMF Recon
Running script JAMF Recon...
Script exit code: 1
Script result: Retrieving inventory preferences from https://
Finding extension attributes...
Locating applications...
Locating accounts...
Locating software updates...
Locating package receipts...
Locating plugins...
Locating printers...
Locating hard drive information...
Searching path: /Library/Internet Plug-Ins
Searching path: /Users/[domain username]/Applications
Searching path: /Users/[Local Admin Username]/Applications
Searching path: /Applications
Locating hardware information (Mac OS X 10.14.5)...
Gathering application usage information...
Submitting data to https://
There was an error.
Connection failure: "The operation couldn’t be completed. ( error 502.)"
Error running script: return code was 1.
  • July 12, 2019
im seeing this on some computers all of a sudden too
  • July 16, 2019
I second this as well.
  • July 16, 2019
@Mateo137 Do you have a ticket open with JAMF on this or have you got any more info on your situation?
DBrowning
  • September 11, 2019
@CorpIT_eB @hdsreid @Mateo137
Have you gotten a resolution to this? We started seeing this just after moving the a jamf cloud instance last week. I've opened a ticket with Support but they can't finding anything yet.
Im getting the same error when uploading pkg files. Seems to be very random. Opened several tickets, when I do they do some tweaking and then it works for a bit but will fail again.
  • October 30, 2019
I'm seeing this error during recon on several of our machines as well. Did anyone ever get a resolution?
  • January 15, 2020
I'm seeing this on a few too
  • February 21, 2020
did this get resolved - now seeing also
beeboo
  • February 22, 2020
ill add to this that ive been seeing it sporadically for a bit.
1 of a few things can happen, and ill list in them from least to most common:
1. either it fails the recon, and actually fails, then it says it will upload the data on next check in. probably internet related, but 1/100
2.recon fails with the 502, but if you refresh JSS itll show the updated info (i can only verify on the 2 EAs that im keeping an eye on) - 1/20 or so
maybe just a glitch, maybe a fluke, but 99%+ of the time, at least it seems to me, the recon is actually going through.
granted, im us-east-1, so im getting maintenance for at least another 3-4 hours.
maybe thatll fix something.
on that note, does plist changes in config profiles work for you guys?
i see the option to choose the jamf stuff along with what version mau, but when it comes to the actual plist settings, its blank :(
sherwin
  • February 28, 2020
I am getting it too, sent in trouble ticket to JAMF.
  • March 18, 2020
any update on this any one?
  • March 19, 2020
I'm getting this often as well!
  • April 24, 2020
I am having the issue as well and is affecting my whole provisioning workflow.
  • May 2, 2020
Same issue also for me with a script "sudo jamf recon" on the Self service... I don't know why
  • January 15, 2021
Same issue while uploading a small pkg. Any resolve?
JKingsnorth
  • October 28, 2021
Has anyone resolved this? Seems to be part of an issue we are having with devices not checking in.
mickl089
  • November 11, 2021
Same problems here since this morning...
landonletzkus
  • January 14, 2022
Hey all! Has anyone successfully worked through this with Jamf support? Seeing it on a sizable chunk of devices over the past week. Have a ticket of my own open, but thought I'd check with the hive mind as well 🙂
  • January 14, 2022
There hasn't been a solution since I posted this. To be honest I stopped seeing the issue but I don't doubt that it still happens for others.
@landonletzkus Let us know what JAMF support comes up with on the ticket that you have open.
  • February 21, 2022
Any news for this issue ?
BrookesMSK
  • July 15, 2022
have the same issue trying to jamf recon -assetTag
  • August 23, 2022
We've developed this issue as well. It's causing issues with JAMF Admin logins, device enrollments, and recons. Case opened to support.
  • August 24, 2022
Ditto we have the same issue cant enroll new laptops or re-enroll freshly wiped machines.. recon throws back a 502 error.. jamf support hasn't gotten back to us .. Our instance is completely unusable.
dgeiler
  • March 29, 2023
 I have created a Case for the support they are having the cloud support team run queries. I post their solution.
dgeiler
  • March 29, 2023
 We are also experiencing self-service issues.
