I've created a CrashPlanCustomInstallation.dmg and Install CrashPlanPROe.pkg per the JAMF white paper and created a policy to deploy to users. I set the priority for CrashPlanCustomInstallation.dmg to 8 and Install CrashPlanPROe.pkg to 10, so that the .dmg gets installed first as per the white paper.
When I run the policy through Self Service, the installation completes successfully and the CrashPlan PROe client starts up, but I get an error "Unable to connect to the backup engine. Retry?" If I click Yes, sometimes it will then work normally, other times I just get the error again. During one test, the CrashPlan app seized up at the splash screen.
If I deploy the .dmg and then separately deploy the .pkg to a client, it works beautifully, which makes me suspect that the .pkg installation is starting before the .dmg is finished...? Just a guess, I wouldn't have thought that Casper would be even starting the second package until the first was completed. Any clues? I need to get this working solidly before I can put it into Self Service for users.
