I have created a plist to set the default dock but the items that I have added can not be removed. I can add and remove other items, but the initial items that I added seem persistent. What do i need to add to make it full customizable after initial set up?
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>autohide</key> <false/> <key>contents-immutable</key> <false/> <key>largesize</key> <integer>128</integer> <key>launchanim</key> <true/> <key>launchanim-immutable</key> <false/> <key>magnification</key> <false/> <key>magnify-immutable</key> <false/> <key>magsize-immutable</key> <false/> <key>mineffect</key> <string>genie</string> <key>mineffect-immutable</key> <false/> <key>minimize-to-application</key> <false/> <key>minimize-to-application-immutable</key> <false/> <key>orientation</key> <string>bottom</string> <key>position-immutable</key> <false/> <key>show-process-indicators</key> <true/> <key>show-process-indicators-immutable</key> <false/> <key>size-immutable</key> <false/> <key>static-apps</key> <array> <dict> <key>tile-data</key> <dict> <key>file-data</key> <dict> <key>_CFURLString</key> <string>/Applications/Launchpad.app</string> <key>_CFURLStringType</key> <integer>0</integer> </dict> </dict> <key>tile-type</key> <string>file-tile</string> </dict> <dict> <key>tile-data</key> <dict> <key>file-data</key> <dict> <key>_CFURLString</key> <string>/Applications/Google Chrome.app</string> <key>_CFURLStringType</key> <integer>0</integer> </dict> </dict> <key>tile-type</key> <string>file-tile</string> </dict> <dict> <key>tile-data</key> <dict> <key>file-data</key> <dict> <key>_CFURLString</key> <string>/Applications/Firefox.app</string> <key>_CFURLStringType</key> <integer>0</integer> </dict> </dict> <key>tile-type</key> <string>file-tile</string> </dict> <dict> <key>tile-data</key> <dict> <key>file-data</key> <dict> <key>_CFURLString</key> <string>/Applications/Safari.app</string> <key>_CFURLStringType</key> <integer>0</integer> </dict> </dict> <key>tile-type</key> <string>file-tile</string> </dict> <dict> <key>tile-data</key> <dict> <key>file-data</key> <dict> <key>_CFURLString</key> <string>/Applications/Notes.app</string> <key>_CFURLStringType</key> <integer>0</integer> </dict> </dict> <key>tile-type</key> <string>file-tile</string> </dict> <dict> <key>tile-data</key> <dict> <key>file-data</key> <dict> <key>_CFURLString</key> <string>/Applications/System Preferences.app</string> <key>_CFURLStringType</key> <integer>0</integer> </dict> </dict> <key>tile-type</key> <string>file-tile</string> </dict> </array> <key>static-others</key> <array> <dict> <key>tile-data</key> <dict> <key>arrangement</key> <integer>2</integer> <key>displayas</key> <integer>2</integer> <key>home directory relative</key> <string>~/Downloads</string> <key>label</key> <string>Downloads</string> <key>showas</key> <integer>1</integer> </dict> <key>tile-type</key> <string>directory-tile</string> </dict> </array> <key>tilesize</key> <integer>68</integer> <key>version</key> <integer>1</integer> </dict> </plist>
