Hello-
I’m working on a Cisco VPN package. During the install it creates a symbolic link from /private/etc/CiscoSystemsVPNClient -> /etc/opt/cisco-vpnclient. When I make the package, it puts the contents of cisco-vpnclient in a directory called CiscoSystemsVPNClient and makes it a folder. This breaks the package when overriding the current users, but this content is need for VPN connections. I have tried to delete the CiscoSystemsVPNClient directory and then re-add the directory as an alias, but each time I search in the OS, the symbolic link is followed. I know that some how this is possible, as I have a package that was made for the previous version that has a Alias folder for CiscoSystemsVPNClient.
Any help would be greatly appreciated. :)
Thanks,
ryan
![external image link](attachments/37b07a9b094041f5beff5ef92fe4cf72)
Hi Ryan,
Just curious why you're repackaging the Cisco client? Cisco is one of those companies that I trust enough to deploy their packages.
Um...after I snapshoot the install so I can verify what it's doing. :)
Citrix is one of the (many) that I don't trust...
http://donmontalvo.com/citrix/citrix-pkg-from-hell.png
That said, there are still some issues with Composer...I use it, but I still find myself going back to Packagemaker/Iceberg at times.
Don
Hello All-
It turns out that I needed to go into the Application Support folder and
edit the file structure there to get the Alias to show up properly in
Composer.
I was using Composer so that I could also distribute our specific
configuration. It turns out that this works! I was able to get it to
install properly. The system requires the VPN subsystem to be restarted, or
the machine needs a reboot, but then it worked like a champ! :)
We would like to use the Snow Leopard built-in VPN, but haven't as of yet
figured out how to package those settings.
Thanks all,
ryan
Hi Ryan,
We've run into issues with aliases vs symbolic links when packaging. Glad you were able to resolve things. :)
Don
