Crowdstrike Falcon Sensor v6.11+ Big Sur and M1 Deployment help
  • Nov 21, 2020 4:52 PM UTC
  • 30 replies
  • 673 views
Show first post
afarnsworth
  • Feb 25, 2021 11:53 PM UTC
@danny.gutman You can configure a Notifications payload using the bundle identifier
com.crowdstrike.falcon.UserAgent
donmontalvo
Forum|alt.badge.img+36
  • Apr 8, 2021 7:07 PM UTC
@afarnsworth like this?
<plist version="1.0">
    <dict>
        <key>NotificationSettings</key>
        <array>
            <dict>
                <key>BundleIdentifier</key>
                <string>com.crowdstrike.falcon.UserAgent</string>
                <key>NotificationsEnabled</key>
                <false/>
                <key>AlertType</key>
                <integer>1</integer>
                <key>ShowInLockScreen</key>
                <false/>
                <key>ShowInNotificationCenter</key>
                <false/>
                <key>BadgesEnabled</key>
                <false/>
                <key>SoundsEnabled</key>
                <false/>
            </dict>
        </array>
    </dict>
</plist>
Doesn't seem to stop the user from getting macOS Notification about the app.
Eltord
  • Apr 12, 2021 1:52 PM UTC
@afarnsworth Hi, I was wondering how you found the correct bundle ID to use for the notifications payload. I tried doing the osascript -e "id of app "appName"' method but got a different one, and couldn't find the correct one until I saw your post here.
@donmontalvo You can use the notifications payload in Configuration Profiles in jamf to do this for you.
  • Dec 6, 2021 4:05 AM UTC
Any updates on this?
  • Aug 26, 2022 3:13 PM UTC
Here is my setup in JAMF.  It works at surpassing the initial notification from the Falcon sensor installer.  As @afarnsworth said you need to use "com.crowdstrike.falcon.UserAgent" as the bundle ID for the notifications payload.
Not really sure if Falcon ever sends out messages via notifications and if you want to disable or enable them.
