CS4 vs CS3
  • October 2, 2009
  • 8 views
When we install CS4 via Casper using the JAMF reresource kit method it seems to break our existing CS3 installs. We get a licensing error when we launch CS3. Has anyone else experienced this? If so, what have you done to get both CS3 and CS4 working together after a Casper CS4 install?
Tommy Birchett | The Martin Agency| 804-698-8592 | 804-389-3071
1 reply
Forum|alt.badge.img+31
  • October 2, 2009
CS4 is extremely broken for me. I am installing it manually. When I install it via Casper policy it sometimes works, sometimes skips a few apps and sometimes just stops half way through. If I use the same installer manually it works 100% of the time. If I install it via post imaging it seems to work better, but I am not about to reimage every computer that needs CS4.
I also tried the things on the resource kit. My adobe CS4 image was downloaded from Adobe directly so it is one DMG file. Last year I created a DMG from the CS3 disks and had zero issues.
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
blackberry: 913-449-7589
office: 913-627-0351
