Custom Extension Attribute Based on Site
  • June 4, 2020
  • 20 replies
  • 223 views
dennisnardi
Forum|alt.badge.img+15
I had a use case that it would have been extremely nice to be able to use an advanced search or smart group to be able to gather data about computers in specific sites. However sites aren't meant to be scope-able per Jamf, and that really made my life difficult. Specifically I was looking for unmanaged computers in the "none" or "Full Jamf Pro" site, and there is no way to make a search for this.
I did some searching and saw several posts of folks who wanted Jamf to make sites a useable criteria, but saw that Jamf specifically said it was not planned (https://www.jamf.com/jamf-nation/feature-requests/1365/smart-computer-groups-based-on-site).
I was able to create a workaround for this and thought I'd share. I first made a custom extension attribute named "Site" with a string data type and a text field for the input type.
Then I was able to make a script utilizing the API to read the current site of a computer and write that data to a XML file that gets uploaded to Jamf and sets the custom EA I created. Once this runs and is finished you will then be able to scope and search based on that custom EA. The script loops through all computers there's a device ID for, and is run locally without the need to be run on each individual computer.
Hopefully others find this useful. Below is my script:
jssURL="https://xxxxxx.jamfcloud.com/JSSResource"
username="apiusername"
password="apipassword"
IDS=$(/usr/bin/curl -H "Accept: text/xml" --user "$username":"$password" ${jssURL}/computers | xmllint --format - | awk -F'>|<' '/<id>/{print $3}')
ea_name="Site"
for X in $IDS; do
ea_value=$(curl -H "Accept: text/xml" -skfu $username:$password ${jssURL}/computers/id/${X} -X GET | xmllint --xpath 'computer/general/site/name/text()' -)
# Create xml
    cat << EOF > /private/tmp/ea.xml
<computer>
    <extension_attributes>
        <extension_attribute>
            <name>$ea_name</name>
            <value>$ea_value</value>
        </extension_attribute>
    </extension_attributes>
</computer>
EOF
# Upload the xml file
curl -sfku "${username}":"${password}" "${jssURL}/computers/id/${X}" -T /private/tmp/ea.xml -X PUT
    done
stevewood
Forum|alt.badge.img+38
  • June 4, 2020
@dennisnardi
We solved this a different way by storing the site value locally in a plist file that gets read in by an EA. We use a policy that runs once a week to grab the site info for the computer and store it in that plist. The policy ends with an inventory update, which pushes the site information up to the server. The advantage of this is two-fold. First, the site info is stored on the device so a tech can easily determine a machine is in the correct site without needing access to Jamf, and second, the site EA is continually updated in case a machine is moved to a different site and doesn't require us to remember to update the EA value manually.
All in all, you came up with a nice way to workaround Jamf's limitations.
dennisnardi
  • June 4, 2020
@stevewood Yeah, that's also a good idea. In my environment I'm in the process of migrating computer records from multiple different Jamf servers into a central one, and if it's just a record and the computer hasn't itself migrated over, then the record is "unmanaged", and still checking into the old Jamf server. I'm doing this in preparation for the computer migration so the computer will retain it's user/location/dept/building info. So for my specific purpose I don't think I had a lot of other options. I can also make some kind of scheduled task to automate running the script weekly or what not.
stevewood
  • June 4, 2020
@dennisnardi
We're in the same boat. Migrating ~16,000 devices over to a different server. We have quite a bit of data in the "old" Jamf server that we'll need to migrate over to the new. We will most likely store in our list so we can ingest into the new server easily.
  • March 1, 2021
@dennisnardi Did you create a single EA plist and you dump all your EAs into the single file or do you create one for each EA? (nothing like bringing up a 6 month old thread, right? :) )
KyleEricson
  • August 11, 2021
@dennisnardi  Thanks this is great. I was able to create a EA based on this script.
#!/bin/sh # This will pull the site name jssURL="https://you.jamfcloud.com/JSSResource" username="your" password="your" udid=$(/usr/sbin/system_profiler SPHardwareDataType | /usr/bin/awk '/Hardware UUID:/ { print $3 }') siteName=$(curl -H "Accept: text/xml" -skfu $username:$password ${jssURL}/computers/udid/${udid} -X GET | xmllint --xpath 'computer/general/site/name/text()' -) if [[ $siteName ]]; then echo "<result>${siteName}</result>" else echo "<result>Not Available</result>" fi
dennisnardi
  • August 11, 2021
And nothing like replying to a post 5 months late! I didn't have the skills to do a single plist, so my script created one for each computer. So it takes a second or two per computer to go through the process if I run the script locally. Generally what I do now is set the script to run on each computer on enrollment/check in, so the EA gets set automatically and I don't need to run a script on a local computer that touches 4000+ Mac's now.
  • March 27, 2023
Hi Kyle,
Thanks for the script based on this topic, I tried creating an attribute and somehow it's blank for me. Is there any OS restriction for the above script?
Thanks
KyleEricson
  • March 30, 2023
Hi Kyle,
Thanks
I don't think so just make sure that you allow for legacy API in Jamf Pro and that the username and password are correct for the script. Also make sure that a recent inventory has ran.
stevewood
  • March 30, 2023
Hi Kyle,
Thanks
Make sure your URL variable contains /JSSResource like Kyle's script has. I missed that in testing just now and the info was coming black blank.
  • March 30, 2023
#!/bin/sh jssURL=https://***********.com/JSSResource username=test.api password=******** IDS=$(/usr/bin/curl -H "Accept: text/xml" --user "$username":"$password" ${jssURL}/computers | xmllint --format - | awk -F'>|<' '/<id>/{print $3}') ea_name="Site" for X in $IDS; do ea_value=$(curl -H "Accept: text/xml" -skfu $username:$password ${jssURL}/computers/id/${X} -X GET | xmllint --xpath 'computer/general/site/name/text()' -) # Create xml cat << EOF > /private/tmp/ea.xml <computer> <extension_attributes> <extension_attribute> <name>$ea_name</name> <value>$ea_value</value> </extension_attribute> </extension_attributes> </computer> EOF # Upload the xml file curl -sfku "${username}":"${password}" "${jssURL}/computers/id/${X}" -T /private/tmp/ea.xml -X PUT done exit 0
  • March 30, 2023
This is what I have updated and please correct me if I need to modify it.
stevewood
  • March 30, 2023
So what you have posted would be a script that would run off from a policy and not as part of an EA. Instead what Kyle posted can be placed into an Extension Attribute and run that way. That would be more secure since the credentials would not get stored on the device, whereas if running a script from a policy the credentials could be visible in the jamf.log file.
Try creating a new Extension Attribute, set the Data Type to String and the Input Type to script and then paste in Kyle's script:
The next time a computer updates inventory, the site value will be placed in the EA.
  • March 30, 2023
Worked like a charm, Thanks Stevewood & Kyle.
MLBZ521
  • April 17, 2023
It should be mentioned that including API account credential in scripts and/or EA is considered very bad practice and really shouldn't be utilized, much less should it be recommended (at least, without a disclaimer).
If you need to do something like this, run it in a script off device.  There is absolutely no need to run this on a device.  Not to mention, these methods only support Macs, so if you have Mobile Devices as well, this doesn't support them.
I've been using my solution since 2018 and it essentially does the same thing, but again, off devices.
Here's my script: jamf_assignSiteEA.ps1; it sets the Site value on every device using the API.  Some notes:
  1. This is a PowerShell script as I run it on a Windows box that runs other automated tasks that my team has setup
    1. It runs nightly and dumps to a log file for review
    2. It checks if the current Site is the same as the Site EA; if it is, it does nothing, if it isn't, it updates the Site EA
      1. Duplicate records will cause an issue here -- the API cannot handle this
      2. Every time the API is used to change a device record, Jamf Pro acts like that is a "Inventory Update" even though it isn't -- this is a known issue with Jamf Pro that Jamf has yet to fix even though there are numerous Feature Requests asking for it
tender
  • April 22, 2024
In the year 2024, this is still useful I just added this as an extension attribute. thanks!
MLBZ521
  • April 22, 2024
And even with it still being useful.....  Jamf rejects any Feature Requests to add this simple criteria into the product........
  • March 25, 2025
@MLBZ521 Do you have any plans on updating your script "jamf_assignSiteEA.ps1" to use the Jamf Pro API instead of the Jamf Pro Classic API?
I ask because I see with the latest release notes for Jamf Pro 11.15.0 mentions that the classic API for computers is marked as deprecated and at some point, will be gone as an option (they mention within a year).
https://developer.jamf.com/jamf-pro/docs/deprecation-of-classic-api-computer-inventory-endpoints?_gl=1*k801za*_gcl_au*MzU0NjcyNjY5LjE3MzcxMzgxODY.*_ga*MTIzMzIyNDU1OC4xNzI1Mzk1Mjk4*_ga_X3RD84REYK*MTc0MjkxNzUwNS45MS4xLjE3NDI5MjE3MjAuNjAuMC4w
  • April 8, 2025
Hey Eric, I realise this is an old post, but do you have an updated or working version of this for the current Jamf landscape?
  • April 8, 2025
I was thinking the same thing about using the new Pro API as the classic is looking at an upcoming sunset, so here's a version for that method I cooked up. Seems to be working ok so far as I'm having Macs reporting when they have a Site of "None" (interesting that Jamf makes that Site ID -1) so I can find them easier since you can't normally make any report or Smart Group based on that criteria. Now it sits in an extension attribute I can report on. I happen to also have a Site named "Unassigned" where devices from ASM land if a tech doesn't assign them to an MDM workflow to direct them to the correct Site. Would be great if the Site level Admins could be given rights to move devices from one Site to another without having full global admin rights.
#!/bin/sh # This will pull the site name and create/update an Extension Attribute to store it. # EDIT THE VALUES IN THIS SECTION FOR YOUR NEEDS! GO TO THE JAMF API SETTINGS TO CREATE AN API CLIENT AND API ROLE TO OBTAIN THE INFO BELOW. # Access Token Template client_id="PUT YOUR CLIENT ID HERE" client_secret="PUT YOUR CLIENT SECRET HERE" url="https://YOURJAMFINSTANCE.jamfcloud.com" ##This output has multiple values, use plutil to extract the token getAccessToken() { response=$(curl --silent --location --request POST "${url}/api/oauth/token" \\ --header "Content-Type: application/x-www-form-urlencoded" \\ --data-urlencode "client_id=${client_id}" \\ --data-urlencode "grant_type=client_credentials" \\ --data-urlencode "client_secret=${client_secret}") access_token=$(echo "$response" | plutil -extract access_token raw -) token_expires_in=$(echo "$response" | plutil -extract expires_in raw -) token_expiration_epoch=$(($current_epoch + $token_expires_in - 1)) } checkTokenExpiration() { current_epoch=$(date +%s) if [[ token_expiration_epoch -ge current_epoch ]] then echo "Token valid until the following epoch time: " "$token_expiration_epoch" else echo "No valid token available, getting new token" getAccessToken fi } checkTokenExpiration # Sanity Check #echo "$access_token" invalidateToken() { responseCode=$(curl -w "%{http_code}" -H "Authorization: Bearer ${access_token}" $url/api/v1/auth/invalidate-token -X POST -s -o /dev/null) if [[ ${responseCode} == 204 ]] then echo "Token successfully invalidated" access_token="" token_expiration_epoch="0" elif [[ ${responseCode} == 401 ]] then echo "Token already invalid" else echo "An unknown error occurred invalidating the token" fi } #~~~~~~~~~~~~~~~~~~~~~~~~~~~# ### Obtain UDID and submit to Jamf to receive the Site Name udid=$(/usr/sbin/system_profiler SPHardwareDataType | /usr/bin/awk '/Hardware UUID:/ { print $3 }') computerInventory=$(curl -s -X 'GET' "$url/api/v1/computers-inventory?section=GENERAL&page=0&page-size=100&sort=general.name%3Aasc&filter=udid%3D%3D$udid" -H 'accept: application/json' -H "Authorization: Bearer $access_token") siteName=$(echo $computerInventory | plutil -extract "results".0."general"."site"."name" raw -) if [[ $siteName ]]; then echo "<result>${siteName}</result>" else echo "<result>Not Available</result>" fi exit 0
  • April 8, 2025
Forgot to mention in the previous comment that the API Role will need to include rights to Read Computers and Read Sites.
