Declarative Management
  • January 19, 2023
  • 4 replies
  • 39 views
xEpicFail_O_o
Is anyone currently having issues with Declarative Management and its rollout? I'm receiving a command failure with the following on all my systems which hit the base requirements of Declarative Management.
Command: DeclarativeManagement
Error/Status: JSON text did not start with array or object and option to allow fragments not set. around line 1, column 0.
JAMF Version: 10.42.1-t1667311080
MacOS: 13.1
Enrollment Type: DEP
Any guidance would be greatly appreciated.
  • Employee
  • January 20, 2023
Hi EpicFail, this is PI-110700. (Product issue)
It will give a message but wont be in the way of other management commands.
xEpicFail_O_o
  • January 20, 2023
Thank you so much @JavierM for the information. Was beating my head over this for the last few days. Glad to know that it's a known issue at least and not something wrong with my setup.
iroman
  • January 26, 2023
@JavierM this a JAMF or Apple "Product Issue" - Don't like seeing this failed command
  • Employee
  • January 27, 2023
Not sure who's to be honest, maybe best to verify with support@jamf.com
