Has any experienced an issue with DEP enrollment not prompting over wireless?
We are testing with a new Macbook Pro that was set up for pre-stage enrollment with DEP. During out of the box set up, we are able to select and successfully connect to the wireless network.
After connecting to the wireless, we proceeded through "Setting up your Mac" and received the standard prompts, expecting at some point to be prompted for DEP, but never were.
Confused by this we began hitting the back button until we returned to the "Select Your WiFi Network" screen. We clicked continue and only then did we receive the prompt for DEP.
We were able to reproduce this behavior several times. There seems to be a large delay between when the wireless network connection is established and when the machine picks up enrollment in DEP. If you've already clicked "Continue" you are never prompted for DEP.
Anyone have any thoughts on this? There is a really good chance that our laptops will miss out on DEP enrollment if this is the default behavior.
