DEP issue - configuration could not be downloaded, "cancelled"?
  • October 18, 2019
  • 21 replies
  • 346 views
When trying to wipe and restore a couple of DEP/JSS managed iPads I am getting a message:
"The configuration for your iPad could not be downloaded from Long Road Sixth Form College"
"cancelled"
Does anyone know what might cause this? There's no firewall between the iPad and our JSS, they're both on the same network, same subnet. Is there some Internet related thing that has to happen when downloading a configuration profile via DEP? We already set up our JSS with an externally-trusted HTTPS certificate, and it hasn't expired, so it shouldn't be that.
Thanks,
Dan Jackson (Senior ITServices Technician)
Best answer by DanJ_LRSFC
This turned out to be that we had renewed our JSS SSL certificate but had forgotten to add the new cert in to the PreStage Enrolments settings. Our iPads are now working again.
  • October 18, 2019
Good Morning Dan,
I am not sure it is the same issue, and you may have already tried it, but we had a lot of iPad minis display a similar message lately. We were able to remedy this issue with a software restore from iTunes. To be honest, I am not sure what the disconnect with the server was or what the restore cleared from the system, but I do know that it worked for us.
Good luck and I hope this helps you!
Chad Krape
Technology Department
Jersey Shore Area School District
  • October 18, 2019
Yes I've tried the restore from iTunes method - holding down Home and Power to put it in recovery mode while connected to a Mac. It restored fine but then when the DEP kicks in during the setup process we get the "cancelled" error again. Unassigning the devices in Apple School Manager does allow us to get in, but then we can't enrol them to the JSS as non-DEP devices require that MDM profiles have to be removable, which we don't want.
  • October 18, 2019
Could it be that our Jamf Pro installation needs to be on the latest version in order to successfully manage iOS 13 devices?
  • October 18, 2019
I've tried to upgrade to 10.15.1 with no success as we are facing the same issue as you. Devices with iOS 13+ will not enroll and the ones already enrolled stop communicating with Jamf. Luckily we pushed out the profile to defer updates for 90 days but a few managed to update before we realized it was a problem. Currently talking with support over it.
  • October 22, 2019
We just updated to 15.1 and have the same issue with iOS 13. In MacOS 15, Self-Service and policies still don't work either.
  • October 22, 2019
  • October 22, 2019
Interesting. The pre-built cert from the primary server is automatically added to the prestage. We also have 3 JSS servers behind a load-balancer for device communication. The primary just handles APN communication. Does iOS 13/macOS 15 also need the the load-balancer cert added now? That wasn't the case before.
  • October 22, 2019
We are still working with Jamf over this issue. We actually have the same setup as lehmanp00 and are running into the same thing. It is strange, like lehmanp00 said, that the SSL cert would be needed in prestage as we never needed that before with the built in certs. I'll give that a try on our test prestage and see what happens.
  • October 22, 2019
We're using a 3rd party SSL certificate for our JSS rather than the built in certificates, if that makes a difference.
  • October 24, 2019
https://support.apple.com/en-us/HT210176
So iOS 13 and MacOS 15 need new/extra attributes in your keys. So we need to generate a new cert, from our JSS system, to the load balancer with the new requirements.
My Network Manager and I are guessing Apple and JAMF are assuming most customers are using a 3rd-party cert, not the built-in certs, and didn't need to worry about this.
  • October 30, 2019
Got this figured out. We had to take the keystorepass from the tomcatconf folder and use the keytool in Java to separate the files into the cert.pem and key.pem. Once that was done we uploaded them to our load balancer.
  • January 29, 2020
@DanJ_LRSFC
We have the Same Problem with Profile Manager. How did you add the new cert into the PreStage Enrolments settings?
  • February 5, 2020
Having same issue. Was able to use Apple Configurator and enroll a device a few short months ago. Now I keep getting "The configuration for your iPhone could not be downloaded...cancelled". Need help.
  • February 7, 2020
reyagarcia88 , Same issue yesterday across multiple schools and accounts. found the server url was slightly different in the AC2 blueprint than that displayed in JAMF under enrol new devices. Rewrote the "prepare" steps in each blueprint with a "new" server... all was good.
I set up a new Blueprint with the server I see on Jamf and get the same error.
Can someone check
  • July 17, 2020
Anyone found a working solution to this hell?
I only experience it on my iPads.
  • September 15, 2020
Have you checked your DEP server token if hasn't expired? If so then the server token needs to be renewed from ASM. Hopefully that helps.
Have you checked if the DEP server token is not expired? If expired then it needs to be renewed from ASM. Hopefully that helps.
  • November 8, 2022
This post saved my sanity. Thanks
SuperMacMan
  • February 1, 2023
Was this for on-prem Jamf Pro? We're having the same issue after migrating to Jamf Cloud, but Jamf said to leave the anchor certificate empty.
  • February 1, 2023
Jamf Pro
