DEP/PreStage Issue - Macs not picking up PreStage
  • Dec 19, 2016 8:47 AM UTC
  • 109 replies
  • 1121 views
Show first post
  • Jul 21, 2021 5:40 PM UTC
@kwoodard Buying directly from Apple is likely the cause here. IIRC only authorized resellers can register devices with your ABM/ASM instance.
If you are purchasing under an institutional purchasing account with Apple that is not the case. You can associate that account with your ASM/ABM. In fact, it's better from this perspective because it doesn't rely on your reseller's POS system integration functioning properly.
  • Nov 22, 2021 5:49 PM UTC
November 2021, and we are having this issue on a stock of M1 Macbook Pro's that were purchased in July...
Has anyone considered also that there is some type of timeout on Apple's side that a device that has sit unopened too long fails to be identified on the first boot network connection? It could be purely coincidental, but our stock of macbooks were purchased and added to our ABM profile on July 21, 2021. Jamf enrollment has been working for us perfectly...until October 21, 2021. Our last successful "no issue" enrollment was October 20.
Since then, the few that we have opened fresh out of the box have had the failure, and we have had to wipe them to get the DEP enrollment started. I'm not saying the above reasons are also not true, but I can't help but think it also has to do with the devices not being online for exactly 3 months...
  • Nov 22, 2021 5:54 PM UTC
@Scott_Conway   I have had my deployment team charge the macs that have been sitting on the shelf for a long time before they enroll them and I don't seem to have that issue anymore.
kwoodard
  • Nov 22, 2021 7:00 PM UTC
I have seen this as well. If the Mac is under 25% charge, I have a very high rate of them not being picked up by the pre-stage. If they are higher than that, I have had one or two out of 50.
  • Nov 23, 2021 10:48 PM UTC
currently doing a batch of 80+ devices through DEP, all m1 with big sure so far, the experience has been much better regards to DEP. I believe the issue is specifically occurring at the ASM, check process, as i understand it, we aren't all sharing the one server, so the experience from country to country will ultimately be different. having a strong internet and wifi connection to the devices, I think is a key factor, limiting to no more than 12 to one WAP would be advised especially if a-lot of packages are being pulled down. But I believe the performance of ASM, and its activation check after the devices connects to wifi, has been modified of late, as some do take longer to process the check for ASM DEP activation status.
I suppose battery could impact this also, as power management could impact the functionality of the hardware connectivity etc. e.g. the haptic feedback of the trackpad is not available when battery is low.
  • Nov 29, 2021 3:43 PM UTC
I would agree about the strong network connections or battery life, however in our situation, the DEP enrollments works after it initially fails, and then you wipe the machine (using the same network as before).
This leads me to believe there is some kind of issue on Apple's activation network.
  • Nov 29, 2021 9:34 PM UTC
I would agree also, and possibly a regional issue also.
I can say it's improved in Australia over the past year.
  • Feb 2, 2024 10:48 PM UTC
I'm seeing this occasionally as well. If I reinstall the OS DEP picks it up but was wondering if there was a better way to get it to recognize DEP..
Even after reinstalling, I still got the wrong time and it did not pull DEP :(
  • Feb 11, 2024 3:26 AM UTC
All through the past few week I have been seeing a time server issue with automatic time settings, something on the specific machines, blocking the time server, manually setting time should fix this. presumably screen time settings or a firewall setting or website anonymiser setting causing the underlying issue.
