DEP problems "a profile containing an MDM payload must be removable"
  • October 19, 2015
  • 8 replies
  • 183 views
I've been playing with DEP and a teacher ipad with an icloud backup. I could not get the backup to restore and have the ipad in DEP so I gave up on that thought and went to restore it and reenroll manually though the jss enroll site, but now I continue to get the above message. I have wiped this ipad at least 7 times, it has no current profiles installed and now I cannot get it back onto management no matter what I do. The teacher does require the backup to continue with her work.
Any ideas?
Gabe Shackney
Princeton Public Schools
Best answer by ktoth
Deleting the device from the JSS and then reenrolling it worked for me!
  • October 19, 2015
In your JSS, what profiles do you have? Sounds like something in your JSS is trying to push with a certain policy that is giving you an error.
  • October 20, 2015
First and foremost, are you using the DEP to try and supervise the iPad?
Apple actually has an intended fail safe -- If a backup is created on an unsupervised iPad, if that iPad become supervised by any means (in this case the DEP/Pre-stage enrollment), restoring the backup to the same iPad it will remove the supervision. When you restore the backup to the same iPad, we've seen no sign that it registers the Pre-stage enrollment. Again, this is an intended "feature" by Apple due apparently to some litigation.
The error you're seeing may be a result of a pre-stage enrollment and the fact that the iPad would be unsupervised when the teacher's backup is restored. I would try removing the iPad from the pre-stage enrollment scope and then using the enrollment site to try and remove it (especially if you had checked the "Disallow MDM Profile removal button" in that pre-stage enrollment.
  • February 8, 2016
Reading the above posts I have checked and the device is already removed from DEP but we still receive the error stating the profile must be removeable.
Can somebody please advise?
Thanks
Kevin
  • March 1, 2016
Can anybody please confirm if there is a fix for this as I have the same issue after rebuilding an ipad that was on DEP from backup.
Device is no longer on DEP and i have set all config profiles to be removable and the issue persists.
Any help is greatly appreciated.
Thanks
Kevin
mblair
  • May 12, 2016
Delete the Record from the JSS to re-enroll the iPad.
  • November 21, 2017
Same problem here
  • January 14, 2019
  • August 29, 2019
ktoth's advice worked for me
