DEP Sync Failing
  • December 9, 2019
  • 71 replies
  • 366 views
I've noticed lately that ASM is not syncing with JSS intermittently, it will come up with the error:
Sync failed. Awaiting next sync.
I've already placed public token in ASM and have uploaded the ASM token to JSS. No changes have been made to our firewall or filtering system.
We are on version 10.17.1
Is there anything I'm overlooking?
Best answer by bentoms
Sounds a lot like: https://macmule.com/2019/10/01/more-dep-sync-errors/
  • December 9, 2019
We are on JP 10.15.1 and we are seeing the same thing.
  • December 9, 2019
same here and we were on 10.8 then upgraded to 10.13 and still having the issue
  • December 9, 2019
Had to replace our DEP token today for that same issue. Nothing on our end changed. Once we redid the DEP token it died again. I keep wondering why this would just fail randomly. We are on 10.16.1
Gabe Shackney
Princeton Public Schools
dan-snelson
Forum|alt.badge.img+30
  • December 9, 2019
We're seeing this as well in our Stage lane (Jamf Pro 10.17.1) and our Production lane (Jamf Pro 10.16.1).
Case #: JAMF-0841146
AppleCare Case No.: 100971412807
  • December 9, 2019
Apple seems to keep having issues either provisioning new nodes for ABM or in a maintenance script, as certain ABM nodes lose the ability to accept TLS1.3 from time to time.
  • December 9, 2019
Id see this pop up the odd time, but after waiting 15-20 mins and rechecking all seems to be ok.
Person
  • December 9, 2019
Yes, I am running into this today as well. Seems like an issue with Apple side.
  • December 9, 2019
We've seen this a couple times in the past month. Only really matters if you're moving stuff from prestage to prestage and want to reprovision right away. Annoying.
gcarmichael
  • December 9, 2019
Ive seen it since 10.14.0 forward on and off. Especially after the legacy vpp/dep portals have gone away. Check back in on it an hour or so later and it seems to be fine.
  • December 9, 2019
Echoing that we've seen it in 10.15.1 ans 10.17.0, thanks for sharing the ticket numbers @dan-snelson.
bentoms
Forum|alt.badge.img+35
  • December 9, 2019
  • December 10, 2019
Can confirm that @bentoms fix worked. Added -Djdk.tls.client.protocols="TLSv1,TLSv1.1,TLSv1.2" to the Java Options in the Tomcat Properties, restarted the JSS, and ASM sync'd right away. Thanks!
  • December 10, 2019
I modified the JAVA_OPTS in my setenv.sh file on my jss master node to this and it resolved the issue:
export JAVA_OPTS="$JAVA_OPTS -Xmx8192M -Xms256M -Djava.awt.headless=true -Djdk.tls.client.protocols="TLSv1,TLSv1.1,TLSv1.2""
  • December 10, 2019
Just had this on an instance and Ben's fix worked for me as well.
A little concerned about enabling TLS 1.0 and 1.1....
  • December 10, 2019
no issues until today, modified my JAVA_OPTS as mentioned above, working now. RHEL 7 with RHEL OpenJDK 11.0.3
  • December 10, 2019
I also added the line -Djdk.tls.client.protocols="TLSv1,TLSv1.1,TLSv1.2" which resolved the issue. Thanks!
  • December 10, 2019
That fix worked for us, thanks! I still can't enroll iPads via DEP but thats another issue.
jbisgett
  • December 10, 2019
We have been getting the sync errors on and off for a couple of months, but they would always resolve themselves after a few sync attempts. Today was the longest run where the syncs had consistently failed for over a day.
Modified the setenv.sh on my Ubuntu master as mentioned above and all errors went away immediately after restarting the servers.
  • December 10, 2019
This fixed ours as well. I only need to add TLSv1.2 and everything seems fine.
  • December 11, 2019
@m.donovan ditto, just re-applied the fix with only TLSv1.2 and sync is still good. That made my Security brain much happier.
  • December 11, 2019
Tested successfully with -Djdk.tls.client.protocols="TLSv1.2" on Jamf Pro 10.17.1. Thanks a lot for the tips
  • December 11, 2019
if you are editing the setenv.sh file manually, it's required that the addition is added thus: export JAVA_OPTS="$JAVA_OPTS -Xmx4096M -Xms512M -Djava.awt.headless=true -Djdk.tls.client.protocols=TLSv1.1,TLSv1.2"
otherwise, Tomcat will not startup.
as soon as I added it, bingo! We're back communicating again...
  • December 11, 2019
Followed the above added -Djdk.tls.client.protocols="TLSv1,TLSv1.1,TLSv1.2" and its just started syncing for me again, i also managed to update token whilst i was at it (although we had till July 20. Thanks.
  • December 11, 2019
any assistance as to where to add that to a macOS instance
  • December 11, 2019
I applied the above solution by HVIKE. After I restarted our JSS I came to the wonferful screen of Unable to connect to the Database...
I have followed this KB to solve this. https://www.jamf.com/jamf-nation/articles/135/title
All was correct and it did not solve the issue.
Only after I removed the line "-Djdk.tls.client.protocols="TLSv1,TLSv1.1,TLSv1.2" and rebooted our whole JSS environment it started working again.
Please be carefull by performing the provided solution as it did our JSS environment not good.
If people have a other solutions on how to perform this, I would be glad to hear it.
Because our DEP does not sync at the moment en we need to enroll our Devices manual.
We use Server 2016 for our JSS, and the version is 10.17
